Results 1 to 7 of 7
Thread: flywheel reccomendations
    Apr 2018
    Olalla, WA
    Disassembled a 1988 302 from the junk yard to go in a MK4 and it is now at the machine shop getting re-worked. Going to have a T5 tranny and I need recommendations for a flywheel. Also need a cam for street use - no racing just out having fun. I'm sure there will be a lot of ideas out there.
    Lost Wages, Nevada
    Stick with the factory flywheel for everyday street use - that way makes it a lot easier to match everything up when assembling your drivetrain.
    A good street cam would be any of the FORD "lettered" cams (B, E or F) , I personally run an "E" cam in my [basically] stock 5.0. Good gas mileage, plenty of low end torque and is slightly weighted toward the exhaust timing so if later down the road you want to add "power-adders" like blower, turbo, etc., no need to swap to another cam. Factory roller lifters are good for the cams mentioned and are inexpensive. Roller rockers in the factory ratio will keep you from any piston to valve issues. Put stronger springs on it . . .
    Doc
    Different opinion here. I say go featherweight on the flywheel. It will transform an otherwise mild mannered street motor into something racy. Well worth any negatives. It will idle rougher, be more difficult to start off in 1st, and have a snappier rev. Yes it will be a bit unruly, but well worth it.
    I'm with Big Blocker. Stock flywheel, E cam......later on add a Powerdyne with 5lbs boost...da bat
    Raleigh NC, OIB NC
    Stock weight. Best for a street occasional track day car.
    Kevin
    MKIV #8234
    Northern VA
    I have stock weight flywheel, with a B cam (B303). Go with that, an E303 or a Trickflow stage 1 cam. I believe you will need stronger valve springs.
    Senior Member GThompson's Avatar
    Spencerport, NY
    I’m with Mike, go light! I’ve got light flywheels in both my Type 65 Coupe and my e36 M3 and they made them both more fun!
    George T
    Type 65 Coupe #338, Picked Up 4-Aug-07, Roller on 8-Mar-09, 1st start 8-Sep-13, 1st Autocross 7-Oct-18, finished sanding & sprayed paint myself 6-Nov-21, IRS/LCA/Koni/traditional gages/Kirkey/pin-drive rear width/15" Torq-Thrust Ds/44IDFs/Brodix ST5.0R heads/Eagle internal-balance crankshaft/oil pan by Armando/home-made turkey pan/S-10 mid-shift T5
