Results 1 to 8 of 8
Thread: FFMetal Battery and clearance Replacing battery with Optima or other
    mcwho's Avatar
    DeBary - Florida
    I have a MKIV with the original IRS, Installed the battery before we put the body on. Used a odyssey pc680. After 4 years it will not hold a charge. Car was just finished and the battery sat most of the time.
    Looking for a battery size that will fit without removing the body, size 34 looks like it may work, the FFMETAL site says to use the optima 9002-02 red top battery.
    Anyone have experience with this or a NON odyssey regular battery, such as a group 34 size. Without taking the body off the car.
    Baghdad Bob
    BadAsp427's Avatar
    Greeneville, TN
    Check out this LINK... I just did my battery.... This seems to be a really nice battery for this application. And FWIW, I measured the Red Top side by side with this one and they have the exact measurements top to bottom, and at the bottom, front to back and side to side... Group 34 is what you need, just watch your post orientation to be sure + / - is on the side that you prefer.
    I think mine is a Duracell. I know it is a group 34. I bought it from batteries plus. Sam's had a sale on for the 34R, which has the post reversed. My positive cable is on the passenger side and the battery sits with the post on the rear of the box. I did have to cut a small tab on the top sides near the battery handle for the hold down bolts to be plumb. The fit is so close, it has to go into the bottom of the box, straight down. It will not drop in, one side then the other. It will clear the hoop in the trunk. Hope this is the right application you wanted info on.
    mcwho's Avatar
    DeBary - Florida
    BadAsp427,
    Oriellys is my parts store of choice here, will get one of theirs today. Did you install or remove the battery with the battery on th car yet?
    Baghdad Bob
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    Baghdad Bob,
    Just for clarification, is your battery sunken in the trunk or on the upper trunk (Factory Five std. location)?
    I have had the battery in both locations (long story) on my Mk4 and the Red Top Optima size recommended by FFMetal (Grp 34) can be removed with the body on in both locations.
    The suggestion regarding making sure the + & - poles are oriented correctly to your cables is important.
    Scott
    BadAsp427's Avatar
    Greeneville, TN
    I do not have body on as of yet but the should be no problem as it is the same size as the red top.
    mcwho's Avatar
    DeBary - Florida
    I went with a Delco size 47 AGM, fits perfectly.
    Baghdad Bob
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    I have an Optima Red Top in my MKII, date coded 07/05 and is still fine. I do keep a Battery Tender hooked up though.
