Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Thermo-tec templates
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    I'm using the brown paper that came with all the boxes as a template for my Thermo-tec insulation. Since I'm not using the carpet that came with the kit these templates will also be used to cut the new carpet when I get there...many many years from now. Do I cut the insulation all the way to the edge, and then use something to open the hole, like the blue lines,
    Or do I just go to the bend, and leave the edge uncovered like the yellow lines?
    Also how much Thermo-tec do I get? I plan on doing the footboxes and the floor. Or do I just do the footboxes? Suggestions?
    "Doddmoore," Mitchell Moore on facebook, Follow Tonks347Cobra on Instagram
    MK IV Complete kit, SB Ford 347, Holley Sniper EFI, TKO 500, Moser 8.8 Solid axle, Wilwoods, Power Steering
    My Build Thread: Tonks347, The Baker's Build
    Slow and steady wins the race.
    Jun 2015
    Ancaster, Ontario
    I used 70 square feet of XMat from Eastwood. I applied it to the fire wall, blank spots on the inside dash, foot boxes, cabin and trunk with just a few scraps left over. No need to go right to the edges in most places.
    MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
  3. Thanks doddmoore thanked for this post
    Jun 2015
    Fairfax Station VA
    I agree; no need to go to the edge. It's unlikely you'd get the panels to fit together properly with a layer or two of insulation between them anyway.
    MK IV Roadster #8631
  5. Thanks doddmoore thanked for this post
