Thread: Rear Springs
    Heart of Dixie, Alabama
    Rear Springs
    MKIV, New model IRS, FFR Koni's with 400 lb springs on the rear.
    While putting the nut and bolt stuff on the car, I probably did not notice or question the spring rate.
    Recently, I noticed the 400 lb rear springs. Are these too stiff for cruising and occasional track passes? If I need to change them, now would be time for me.
    thanks,
    edwardb's Avatar
    My 20th Anniversary Roadster with the same setup -- 2015+ IRS, dual action Koni's, 400 lb springs, and sway bar -- rides really well. Smooth and quite compliant. Not harsh at all. Everyone who rides in it, and I've given a bunch of rides, comments about how nice it rides. And our roads here in Michigan are not the best. Others may suggest lighter springs, and I admit I haven't used anything but the 400 lb ones. But I'm very happy with them.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
    Edwardb, glad you responded. I wanted to hear your evaluation of the springs. I am sure they will be OK, now.
    Manassas, Va.
    To some extent ride is a personal taste thing. Ride is also heavily dependent on shocks. I upgraded to the 2015 irs on my MkII and prefer 350# springs w/ my DA QA1s
    A 50 lb difference may not be out of range for OK. I have a '23 T bucket with a buggy spring front and rear, so I will know if it is too stiff. Thanks for the input.
