Clutch pedal interference issue addressed on latest frames?
I have a Mk4 roadster kit on order, with a Dec. 22 'ready for pickup' date. I'm still deliberating on is the powdercoat option for the frame. I've heard rumors that the newest frames have resolved the clutch pedal interference issue, and a frame mod is no longer required. Can someone that's recently received a chassis confirm whether this is, in fact, the case? I've seen that some folks are modifying the clutch pedal itself. Not 100% decided on pedal vs. frame mod (if a mod is stll required) but if a frame mod is still required I may take this as an opportunity (excuse) to receive the frame bare, clean up any weld splatter, make the needed mod for the clutch pedal, and PC it in the color of my choice. If the clutch pedal interference issue is no longer a problem on the newest chassis, I'd probably call it 'good enough' and receive the chassis already powdercoated.
