Camber/Caster Measurement Question
I understand that the camber/caster gauge must be square to the spindle, but is there any requirement for the camber/caster gauge to be in any particular vertical plane, such as the edge of the rim?
I think I want to build a fixture so that I can easily measure my camber & caster without having to remove the wheel spinner (recognizing of course that any adjustment would almost certainly require taking the wheel off).
MK IV Roadster #8631
