Wiring Questions
As I plod along with the wiring, I ran across a couple of items that I'm not sure how to proceed.
First, I thought that I had read, somewhere on the forum, that the radio circuit could be used as power for a power port. I had purchased a pair of power ports, one a cigarette lighter style, and the other a USB. Would the radio circuit, with possibly a larger fuse, be enough to handle the power for both ports?
Second, I'm installing an additional fuse panel, a Blue Seas 12 position, with them divided 6 and 6, powered all the time, and in run only. I figured that the "in run only" would need to be routed through the ignition switch, but I thought, again from something that I read here, that it's not a great idea to connect something like this, (fuse panel), directly to the ignition switch. If that is the case, how can I power this side of the fuse panel, and not chance frying something else, like the ignition switch.
I guess it's starting to make sense why this is taking me so long!
Thanks.
Rick
