Can not fill at the pump
Hi
I have a Boyd Tank on my 33 with a 2"dia 90 degree bend rubber filler hose and a FF stock gas cap. At first I put gas in from a gas can and had no problems. Now I have a 60 day temp plate to shake the bugs out of my 33 and I took it to a gas station. After 10 minutes I only managed to get a qt or two in the tank with some in my trunk. No matter how I turned the nozzle it would overflow or click off. I even turned the nozzle facing the curve and it only clicked off.
I read all the head aches over the FF tank, so I went with the boyd tank and I still can not fill at the pump. Anyone had a similar experience and is there a cure.
My tank is vented with a roll over ball vent. I have driven the car about 100 miles and the fuel system works great. I run a 750 Holley with an external fuel pump on a return fuel system, regulator @6.5 PSI.
I would appreciate any help.
Thank You
TomH33
