427w clutch recommendations
I am looking for some recommendations for good clutch. My engine is a 427w with 550hp with a TKO 600. I want a snappy high performance clutch that can handle some aggressive launches but still has drivability to the point that I’m not fighting to drive it around town and my girlfriend is not yelling at me as I chirp tires at every start?
Mike Forte hooked me up with a RAM Powergrip (98794T) for my 427w and TKO600. Good for 550HP.
I'm running a CF dual friction with 520+ ft/lb drives great no issues. Scott
I've run the McLeod RST, 427W same basic config & HP as yours. Nice clutch, light pedal. I'll use the RST again for the current build.
Friends are running the RXT which handles more power with good success. I've also run a Centerforce Dual Friction with a similar motor, seemed to be a nice piece.
Jim
