Thread: Preferred Coolant For Iron Engines With Aluminum Intake & Radiator
    What coolant do you guys prefer for your "Iron Engines" sporting aluminum intakes and radiators?
    • There are so many coolant types out there that they've got my head spinning.
    • My climate is mild so the car will never be winterized & stored.
    • Living in the Deep South has some advantages.
    • Hurricane Season Isn't One Of Them!
    Thanks-N-Advance!
    Rotonda West Florida
    I'm going to try waterless
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I have waterless in mine and so far so good. I had to drain it once to replace the oil pan and water pump gasket but I used a clean pan and put it back in. If you've ever had water in your system there is a flushing chemical you have to use first which costs as much per gallon as the coolant. Once it's in the coolant lasts basically forever.
    JR
    Seasoned Citizen NAZ's Avatar
    For my street cars I use whatever the OEM recommends -- these are usually longer lasting types (none last forever). However, for my race car I use the tried and true 50/50 premix (I use Peak but choose your brand) ethylene glycol. It's relatively cheap and easy to get rid of. I also have to pull my engine every two-years for SFI certs so the coolant will never stay in there long enough to gel up.
    Chino Valley, Arizona
    I also use an anode plug that I replace yearly as it’s eaten away to deal with the galvanic effect of the dissimilar metals. Got it from Summit Racing and you just need a spare port (mine is in the lower intake). I also add VR-12 a “vitamin” additive for your antifreeze. It has slightly lowered my operating tempature...
    I went with the Dexacool (Prestone Brand) coolant.
    I had that stuff in my old 1995 Corvette that I recently sold to a friend of mine so that he could get back into the Car Hobby.
    https://youtu.be/svZX2BMSDEs
    It is also in Baby Go-Dad's 2000 Camaro.
    https://youtu.be/A5WUZgl6N5Q
    Since those cars have iron blocks, with aluminum radiators I figured why not run that stuff since I've already used it.
    Thanks For The Input Gang!
