Results 1 to 6 of 6
Thread: Preferred Coolant For Iron Engines With Aluminum Intake & Radiator
    What coolant do you guys prefer for your "Iron Engines" sporting aluminum intakes and radiators?
    • There are so many coolant types out there that they've got my head spinning.
    • My climate is mild so the car will never be winterized & stored.
    • Living in the Deep South has some advantages.
    • Hurricane Season Isn't One Of Them!
    Thanks-N-Advance!
    Rotonda West Florida
    I'm going to try waterless
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I have waterless in mine and so far so good. I had to drain it once to replace the oil pan and water pump gasket but I used a clean pan and put it back in. If you've ever had water in your system there is a flushing chemical you have to use first which costs as much per gallon as the coolant. Once it's in the coolant lasts basically forever.
    JR
    For my street cars I use whatever the OEM recommends -- these are usually longer lasting types (none last forever). However, for my race car I use the tried and true 50/50 premix (I use Peak but choose your brand) ethylene glycol. It's relatively cheap and easy to get rid of. I also have to pull my engine every two-years for SFI certs so the coolant will never stay in there long enough to gel up.
    Chino Valley, Arizona
    I also use an anode plug that I replace yearly as it’s eaten away to deal with the galvanic effect of the dissimilar metals. Got it from Summit Racing and you just need a spare port (mine is in the lower intake). I also add VR-12 a “vitamin” additive for your antifreeze. It has slightly lowered my operating tempature...
    I went with the Dexacool (Prestone Brand) coolant.
    I had that stuff in my old 1995 Corvette that I recently sold to a friend of mine so that he could get back into the Car Hobby.
    https://youtu.be/svZX2BMSDEs
    It is also in Baby Go-Dad's 2000 Camaro.
    https://youtu.be/A5WUZgl6N5Q
    Since those cars have iron blocks, with aluminum radiators I figured why not run that stuff since I've already used it.
    Thanks For The Input Gang!
