Results 1 to 15 of 15
Thread: 35 HotRod Truck FOR SALE
    Huntsville, Al
    This is the new Factory Five Hot Rod Truck (Chassis #3).
    It was completed just prior to the 2018 SEMA (Nov 2018) and was on display in the Factory Five Booth
    The truck has a VIN (but the site would not let me add it) and is street legal and currently has a license plate from Alabama. – Registered as a 1965 Ford Truck
    The truck has not been to the track and have only sprayed it twice to get the AFR's correct.
    I will continue to exercise it to keep the fluids moving and the gas fresh.
    Build Video with all the details: https://www.youtube.com/watch?v=HzZ32PB5UCE
    Walk Around and start:https://youtu.be/DKmG2F1fNP0
    Some video inside and outside the truck driving down the road. Nitrous was not used. https://youtu.be/lIG1aZ-UHI4
    PAINT
    Tri-coat, Ford U6 Red from Spies Hecker (3 gallons of color used)
    CHASSIS
    Factory Five Space Frame Chassis with roll cage – custom rear legs added. Completely Custom Powder Coated to match all aluminum panels
    ENGINE
    Engine Purchased new from Summit- . Ford Performance Parts 427 C.I.D. 535 HP Long Block Crate Engines with Z2-Series Cylinder Heads M-6007-Z2427FRT
    IGNITION
    Distributor, Holley EFI Dual-Sync, Male/HEI, Polished Housing, Steel Gear, Black Cap
    FUEL DELIVERY
    Electronic Fuel Injection by Holley Sniper EFI Mater Kit
    TRANSMISSION
    FB Performance Transmission AOD Transmission - manual valve body with transbrake and electronic overdrive. (will support 900hp) – Transmission Cooler installed
    FB Performance Transmission Torque converter rated to 900 ft/lbs.
    SHIFTER
    Hurst Pistol-Grip Quarter Stick Shifter - Hurst Shifter 3162002 –
    POWER ADDER
    Nitrous Express kit installed with 150 shot. w/purge – Controlled through SNIPER EFI
    SUSPENSION
    Rear 4-link rear suspension with 3.08 Gears
    KONI coil overs all 4 corners – adjustable ride height
    WHEELS
    REAR: 15 x10 Weld Racing V-Series Black Anodized Wheels WLD-84B-510212 (Powder coated rim)
    FRONT: 17 x 4.5 Weld Racing V-Series Black Anodized Wheels WLD-84B-1704274
    COMFORT ITEMS
    Vintage Air- Air/Heat with Defrost
    Uni-Steer – Electric power steering
    Power windows – Both Passenger and Driver (driver side has remote control to pass like OEM equipped vehicles)
    Uni-Steer – Steering Column with Tilt
    Seats are Kirkey drag seats... the vintage 17 inch low backs will fit if you are "wide" hipped... HOWEVER... also included is a drop-in replacement bench seat that comes stock with the kit (never mounted). Has fold out arm rest.
    $58,500
    I am only selling because I already have another Factory Five (Gen3 Coupe) and the wife says I can't have 2 if I want to keep building....and Factory Five keeps coming out with new kits…. So the building must continue.
    ABSOLUTELY NO TRADES! but reasonable cash offers will be considered
    $500.00 deposit required to hold the vehicle.
    Thank you
    here are some Hood 2.0 pics... The Air Scoop seems to drive people away... so... if you pull it off I went ahead and found a "hood scoop" that be bolted "pinched" on the hood to allow for two different looks on the same truck..takes about 20 minutes to swap it out.
    Port Charlotte, FL
    I’ve seen (and heard) this car up close. Erik builds awesome cars and trucks and this one is up there with his best! You won’t go wrong with this truck!
    Henry
    Huntsville, Al
    Thanks Sir!
    That is a great deal for some lucky person.
    If you're looking for a fast, absolutely gorgeous truck, this is the one for you! Erik is an incredible craftsman and it shows in this awesome build.
    I have to make room for the next project...only reason for selling at this point.
    Factory Five Hod Rod Truck (Chassis #3) . It was completed just prior to the 2018 SEMA show and has 7 miles on the clock. 2 miles were done during the SEMA Rollout. -
    The Truck was built with a "Pro-Street" theme - the rear chassis cross bar/roll bar is not stock and was added during the build. Also added is the steel roof visor which came off a 1929 Ford
    The Engine is a Boss 427W Crate Engine from Ford Racing - it has the new Z2 heads and makes 535hp. Purchased new this year.
    AOD Transmission is a FB Performance Transmission (will support 900hp) - manual valve body with transbrake and electronic overdrive.
    Full Race Torque converter rated to 900 ft/lbs
    Weld Wheels front and back - rears are 15x10's and front are skinny 17's
    Koni coil overs in all 4 corners
    Truck has AC and Heat as well as power windows and tilt steering.
    The entire chassis has been powder coated as well as the grill.
    The Car was sprayed with a Tri-coat , Ford U6 Red from Spies Hecker (3 gallons of color was used)
    The car has not been to the track and have only sprayed it twice to get the AFR's correct.
    The exhaust sounds like a proper pro-street and the 427 definitely sounds off when needed.
    I am only selling because I already have another Factory Five and the wife says I can't have 2 if I want to keep building....
    Build Fully documented here on the forum
    https://thefactoryfiveforum.com/show...o-Street-Truck
    $60,000
    I was at the Sema Show and this truck looked awesome in person.
    Huntsville, Al
    Huntsville, Al
    *** Bump *** and added a few more pictures.
  9. Thanks CDXXVII thanked for this post
  10. #9
    Huntsville, Al
    New Years Bump and added new pictures and details
  11. #10
    Jan 2019
    Sold??
  12. #11
    Huntsville, Al
    not yet... add more pics up top … hood scoop options now 2.0
  13. #12
    Huntsville, Al
    Sold
  14. #13
    Port Charlotte, FL
    Awesome, congrats Chief!!!
    Henry
  15. #14
    Huntsville, Al
    Thx... I still have it though... he wants to modify the crap out it..lol
  16. #15
    Port Charlotte, FL
    Ah, hence the other post! See you soon!
    Henry
