Likes Likes:  2
Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Thread: LED conversion is not going well...........
    Mar 2017
    What about the third wire going to the lights? You have the ground, the tan we just spoke about, and the third for either brake/parking/turn........would that need anything??
    Build#1: MKIV Roadster #9320
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    The ground circuit is common to the whole car - EVERYTHING shares this.
    The Brake/Turn circuits are mechanically isolated via a switch(s)... read that air - no mechanical connection.
    The common interconnection factor is the parking light circuit which is through the headlight switch, dimmer rheostat, and who knows what else... that at rest is still mechanically connected/touching via various gizmos, but not energized.
    The wonkyness on my particular instance was the parking light circuit.
    John D. - Minneapolis 'Burbs
    Aug 2017
    Minneapolis 'Burbs
    Any Progress?? Curious minds want to know...
    Mar 2017
    Not yet...... body coming off the car during the paint process. I’ll take back to complete carpet etc. I’m going to address your suggestion at that time as it will be easier access to the wiring.
    Mar 2018
    Yucaipa, CA
    I am a bit more than confused why the Ron Francis Wire people, the Proud of their product people, have not chimed in and given all us minions the correct, permanent fix....
    Aug 2017
    Minneapolis 'Burbs
    They built the harness with incandescent bulbs in the design... 80+ yr. history - run voltage/current through a coil of tungsten and it glows - predictable and proven.
    Enter affordable LED's in the last 10 years, produced/offered by who knows, using one of a myriad of methods to illuminate them... enter possible backfeeding via reverse voltage breakdown.
  7. Likes mburger liked this post
  8. #47
    Quote Originally Posted by OnlyAndy View Post
    Quote Originally Posted by Fixit View Post
    Reality check... As I stated earlier, I'm running running the same exact LED bulbs (same source, same bulbs as best we can tell), same solid state flashers, same RF harness, same switches, same wiring scheme, in #8674 and do not have a problem. Has worked successfully from day one with no hint of backfeeding. Now hibernating after two driving seasons.
    Somewhere in this mystery story there's going to be a cause and effect. Just a matter of finding it. LED's will work with this setup. Of course some type of defect with the RF harness is a possibility. But the RF harness itself works. Not sure what anyone would expect from them. I find the headlight switch an interesting possibility. It's a widely available Delco piece. Would cost $25 or so to see if that's the problem.
  9. #48
    Mar 2017
    I have another switch!!!!!!
  10. #49
    O'Fallon, MO
    Have you visually checked the bulb sockets? I remember on one of my builds, one of the turn signal fixture's was bad. The insert with the bulb contacts was out of alignment. Long shot, but maybe worth looking at? Have a look at the alignment of the bulb contacts as well, maybe one or more are slightly off?
  11. #50
    I have had that also. That could be a problem here. Let's say one of the rear 1157 bulbs should have T/S on contact A and brake light on contact B. But they are swapped because of the socket. So now, the T/S signal ends up going to both sides of the car.
  12. #51
    Mar 2017
    The pins in the socket should align directly onto the pins on the bulb........ I’ll take a look at that. Maybe.... you never know!! But every light function works correctly in the correct location on the car. When I get the top off again I’m going to dive into this.
