14
76
Ron, yes I have had the hatch on and operation but still need to ensure I have even and same clearance around the hatch. I removed it to make it easier to reach inside the body to work on side scoops etc. but will put it back on shortly. By the way thanks again for the advice and support....
As others have mentioned, it is really good idea to look for voids in the fiberglass body. Here is one I found on the edge where the hatch flange is and will fill it now that I have it dug out to good material.
Here is the side scoop at the 1/4 window on the drivers side fit up before being made permanent. I have the 1/4 window banks in place and need to finish filling, sanding and will paint the inside flat black before the are permanently attached but this give me a good idea of what they will look like when attached.
