I am using a loom clamp like the one shown below but I remove the adhesive part that is supposed to stick the clamp down. I then drill a few 1/8” holes around the base and rough it up with 40 grit sandpaper, then stick it to the body using the 3M 8115 panel bond. It works great but you to have to remove the foam sticky pad and rough the plastic up at a minimum but the holes insure the panel bond come through to the top the I kind of smooth that out and it is sealed top and bottom. Hope this help or give everyone another way of attaching wire loom to the body.
Post Thanks / Like - 2 Thanks, 1 Likes
