Thanks Thanks:  14
Likes Likes:  76
Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 241 to 280 of 680
Thread: Wyoming GTM Underway
  1. #241
    Newcastle, Wyoming
    Got the steering wheel changed today and work on the back hatch again. I worked on aligning the hatch door making adjustments in the hinges in an attempt to get it centered better in the opening and got the lift cylinders installed so trying to adjust to a happy medium that I can work with. It did not come out exactly like I wanted it but it opens and closes without hitting wing and when all the way open it does not touch the body either so for now will live with it the way it is. I did get the hatch hinges from Shane (VRaptor Speedworks) and they would have worked just fine it I had not run the CAI the way I did, but would rather change to the lifts or possible modify Shane's hinges, I will look at possibly modifying the when I return from the lake. Off in a family outing Sunday for a week so will cut into my build progress but will keep everyone else happy especially the wife.... So to here are some pictures of the hatch again with the hinges installed showing the alignment and how it is now sitting:
    And here is the new steering wheel installed and it does make it easier the get in and out of the GTM:
  2. #242
    Newcastle, Wyoming
    Crash,
    I have a question, can you run or have you run a small permanent by-pass before the heater control valve (assuming you are using the on supplied by Vintage Air) to insure water on both sides of the thermostat? Seem you could add a 1/4" - 3/8" Tee and by-pass a small flow to insure there is always water on the thermostat. Just asking the question as then no matter what happens to the heater control valve there will always be flow on both side of the thermostat.
  3. #243
    James.....have you tried installing the hatch props both ways? With your intake like that, it looks like things will be pretty tight, but you might try installing with the short links on the props to the hinge links and attach the long links to the hatch?
    Shane Vacek
    www.vraptorspeedworks.com
  4. #244
    San Diego
    You could try that. I have not. I figure there is a reason these valves exist. If it were as easy as a small bypass, I don't know why the OEMs would go to the cost and trouble of making the bypass valve?
    Quote Originally Posted by jamesfr58 View Post
    Crash,
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  5. #245
    Senior Member beeman's Avatar
    Indiana
    Probably just for cabin comfort, keeping that hot coolant out of the cabin unless the heater is on?
    GTM #304 LPE 525hp LS3
  6. #246
    Newcastle, Wyoming
    Thanks Shane, I will look at installing them again had planned on doing that but been gone for a week so have not had a chance yet. Hopefully will get to some this week before I leave for the NASCAR races in Vegas next weekend.
  7. #247
    Newcastle, Wyoming
    You guys might be right to keep heat out of the cabin but is running the Infinity box temperature control it will use but heat and air to control the interior temperature as happens in OEM installation in other cars. That is why I was asking the question Mike as I had not seen any try this configuration either.
  8. #248
    Crash,
    We're going to find out. I see no reason this would not work. I just purchased a "manual" coolant shut-off from NAPA for the 5/8 hose to the heater core as well as 2 Tee fittings....one for the 5/8 coolant hose and one for the 3/4 coolant hose...both tees have a 3/8" T in the center.....so the 3/4 hose and 5/8 hose will be permanently connected with a 3/8 hose. When the petcock is closed in the manual shut off, that will dead-head the 5/8 line to the heater core and 100% of the coolant will have to run thru the 3/8 tee into the 3/4 hose. When the petcock is open (if you want heat for the winter) coolant can flow thru the heater core as well as the 3/8 tee. I plan on installing the shut off up front under the hood near the heater core so it's accessible whenever winter rolls around and you want to run coolant thru the heater core.
    Shane Vacek
  9. #249
    Newcastle, Wyoming
    Well, got the third brake light working today, had to dig back into the Infinity Box system and rework the wiring. Of course I had already removed all the unused wires from the Master Cell and the rear Power Cell, so had to add a control wire back in the Master Cell that took some time and add a wire back to the rear power cell, not to bad to get this task done. I had wired the lights, turn and brake lights as mentioned in previous post but when trying to wire the third brake light it finally dawned on me that if I tied it into one of the lead to the rear lights then the third brake light would blink with the turn signal or at least I figured it would so used another circuit on the power cell to power the rear brake light. Here is a picture of the back with the third brake light wired:
    Here it is with the drivers side turn signal on and the passenger side and third brake light on:
    I never tried it wired into one of the 1 element wires to the rear lights and really not sure if it would have worked or flashed with turn signal on the side it was wired to but know it will work this way.
  10. #250
    Newcastle, Wyoming
    Well made it back from Las Vegas and the first race of the NASCAR play off races. It was hot (100 + during the day) there like last year but at least they moved the races to night races instead of the middle of the day. The weather was good and here is picture of the full moon on the night of the truck races.
    Got the air flow straightener (vane straightener) installed in place in the Y upstream of the MAF so should help with the close quarters of my CAI system.
  11. #251
    Newcastle, Wyoming
    Reinstalled the J pipes with direct contact insulation pads attached and covered the cats with direct contact insulation as well. You can also see in the picture that the started is insulated from the heat as everything is tight, and I am trying to mitigate heat soak into other areas where it is not wanted.
  12. #252
    Newcastle, Wyoming
    Installed the exhaust pipe to check fitment in body and clearance to other equipment I might need to protect from the heat as well. The silicone fitting on the CAI should take the heat with no issues.
  13. #253
    Newcastle, Wyoming
    Reinstalled the CAI and routed the air filter into the space behind the cutouts on the body. This was my solution to getting them there with my configurations. Will see how it work with the remaining wheel enclosure and may design something to keep them segregated from everything else in the rear of the car.
  14. #254
    Newcastle, Wyoming
    Wanted to post a picture of the seat I used sitting on sliders in the GTM with the seat back tilted all the way forward. The seat back can move all the way back until you hit the window wall and all the way forward toward the steering wheel and still clear the roof of the GTM. If you can find the right size seat (these were for a fox body mustang. replacement racing seats) they will fit in the car, clear the rood and not het the window glass in the door. Took me two try's to get it right and I still have a set of seat that were to tall to sell but finally got it right.
  15. #255
    Newcastle, Wyoming
    Installed the window wall this morning, had to adjust a couple of things as it did not fit, the cut outs would hit the roll over bars before it went all the way back against frame for mounting. But after a little messaging and a small redo on the upholstery it is finally in and looks pretty good. Won't install the glass until I install it for the final time and it seems I have to install and remove the parts several times to get them to fit the way I want them to. Here is what the window wall looks like installed.
  16. #256
    Newcastle, Wyoming
    Well thought I would post this as it is the single biggest fubar moment so far building the GTM. When I discovered it, I almost wanted to have a full blown come apart, but at the end of the day sucked it up and started to correct the problem.
    Some how or some where when assembling the transmission to the engine I lost or left out the retaining spring for the clutch release lever pivot that ensures the lever stays in place and does not move. Found this problem when I had to remove the clutch slave cylinder that was leaking around seal on piston. Now the clutch slave cylinder was new (it was a Centric) but I could bleed the clutch and have it working and within a few days it would bleed down enough you had to bleed it again. So, we took the slave cylinder off and removed the boot, you could see it leaking slowly past the piston in the slave cylinder, so I order a new one a different brand this time.
    While taking the slave cylinder out I noticed I could move the clutch release lever, which is not supposed to move around on the shaft. So made the decision to remove the transmission to locate the problem. After some time and disassembly of the back of the car we got the transmission pulled and upon inspection notice the retaining spring for the clutch release lever pivot pin was missing, not setting in the bottom of the bell housing just plain missing in action. So back online to order new parts but this time I order all new parts for the throw out bearing (which was new) and replace the older parts that cam with the transmission so it got a Guide Tube for Clutch Release Bearing, Ball Pin for Clutch Release Lever, Clutch Release Lever, Sealing Washer for Clutch Release Lever and the infamous Retaining Spring for Clutch Release Lever Pivot.
    Parts should arrive today and by tomorrow I should be putting all back to gather again with all the parts in the bell housing and hopefully the clutch will work now with the new slave cylinder. I was getting ready to drive for the first time so good thing we caught it now. Here are some pictures of the GTM disassembled and the part missing the $ 1.75 spring…….
    Here is where the spring goes and holds the lever to the pivot pin and the lever in place:
  17. #257
    Newcastle, Wyoming
    On the brighter side at least I know you can get the transmission out with all the other parts in place (with the body off), not sure it could be done with the body on as the cross member on the bottom prevents it from coming out the bottom side. This would be a good place for a removable crossmember like production cars so if one had to pull the tranny you could remove the cross member and remove by lowering from underside of car.
  18. #258
    Newcastle, Wyoming
    While waiting on parts I am gone ahead and started fitting the back wall in the cockpit. Since the window wall was set and in place before we removed the body I can finish the remain back wall sections with the body off with the exception of the corner pieces that need the body in place to finish. It came out well I thing and since I have a good tight fit, believe it will seal up without having to add the extra piece between the back wall and the tunnel to take up space. Here are some pictures of the passengers side, still working on drivers side.
  19. #259
    LCD Gauges's Avatar
    Toronto, Ontario
    Very nice work, I like the colour of the rear firewall.
    What are the hard lines running in front of the water pump?
  20. #260
    Newcastle, Wyoming
    The hard lines that run in front of the water pump (follow the frame and are gold in color) are from the water pump and the steam vents on the passengers side of the car to the header tank on the drivers side of the car. It cut down on the amount of hose crossing over in the tunnel and made of a clean install. The waterfall fits over them without and issue and it was easier to hole the hard lines in place than the hoses. The darker colored hard lines are fabricated radiator lines, they are hard piped through the tunnel and connect on bot ends with silicone fittings. Hope this answers you question
  21. #261
    Newcastle, Wyoming
    Well got my $1.75 spring for the shift lever and the other new part installed and transmission is not ready to go back in. Here is a picture of the spring as it clips onto the ball pin and holds the lever in place, along with the other new parts installed.
  22. #262
    Newcastle, Wyoming
    And since I had the transmission out I decided to look for better mating flanges for the CV joints. Not sure is anyone else has had any problems with this but the normal Porsche CV joint mating flanges for the year of Porsche transmission I have are very hard if not impossible to keep the CV joint boot in place. I tried the normal crimp on bands and now have bands that tighten like hose clamps. The boot would eventually pop off the mating flange given enough time and movement. So I set out the find a better mating flange design and ran across this on shown in a side by side comparison. The aftermarket mating flange has a lip and grove to help keep the CV joint boot on the flange and they appear to work great. I wanted to get this done since the tranny was out and access was fairly simple. Thought I would pass this along as they really din make a big difference and now I don't have to worry the CV boot will pop off the mating flange.
    The one on the left is the normal mating flange with CV boot attachment you would get for sat Pelican Parts, the one on the right is the new ones I found on Parts Geek that have a groove and ridge on the mating flange for the clamp to fit into with the ridge keeping the whole thing in place.
  23. Likes rolfer liked this post
  24. #263
    Newcastle, Wyoming
    Interior starting to look like a car..... got the other back wall (tank cover) installed on the drivers side and will final fit the waterfall today. Next step will be to put the window wall back glass in and that portion of the interior will be done. Also have transmission repaired and hope to get one of my boys to help me reinstall it today so I can begin to put all the pieces I removed back on to the GTM. The engine compartment is coming out like I wanted with the heat reflection covering in place so onward and upward...…
  25. #264
    Newcastle, Wyoming
    Tino,
    The lighter color in my interior scheme is called Cashew, it will also run over the top (headliner) and on the dash to where it meets the darker color called Persimmon that used in the lower half of the interior. Decided to use the darker color where it can get the dirtiest from just everyday use (shoes etc.), and the seats will be recovered in both colors. The two compliment each other and the pictures really don't the contract you can see in person. I hope to paint the exterior Tangerine Pearl but not there yet and still may change my mind of the exterior color. Thought you might like to know the colors used on the interior.
  26. #265
    Looking good! Always exciting to be putting stuff back together for (hopefully) the final time!
    Shane Vacek
  27. #266
    Newcastle, Wyoming
    Well getting it back together again after making the repairs to the transmission and CV joints. The new mating flanges work great and the CV joint boots slip over the lip and stay on the mating flange with out any issues os they did the job and the boot is not falling off anymore. Al got the glass in the window wall and the wall reinstalled so all moving along good now.
  28. #267
    James you are moving right along keep up the good work. it definitely has your spin for all the custom and color matching work.
    Indiana
    Great progress, James. Sorry you had to pull the transaxle...But every time you do something like that you get better at it...
    Any concerns with venting the gas tanks to the engine bay?
  30. #269
    Newcastle, Wyoming
    Not really, believe it or not there are not many fumes that one can smell and since I am using Shane's Aluminum Hatch Cover it will be open anyway. I really do not believe there will be an issue with a lot of fumes but If I am wrong I can change them out. They do have some activated carbon in the filters, not much but some. We'll see how they do and let you know but for now really can't say a lot of fumes are escaping as again I can's smell them unless you get nose right up to filter. And I ting the roof scoop with air flowing and the open to the air hatch cover will make sure there is not a build up of fumes.
  31. #270
    Newcastle, Wyoming
    Worked on fitting the waterfall engine cover today. Because of the interior padding (and you were right Shane) I did have to modify the top portion around the tubing on the section. But final got it on the car, have not drilled the holes to mount it yet will sleep on it and decide tomorrow if I like it where it is now. The front section with the shifter doesn't have the same issue, it even slides around so plenty of room there. Here is what it look like with the engine cover being held in place:
  32. #271
    Newcastle, Wyoming
    Well just got back from Kansas again, trying to help my elderly parents as they need to move from home to assisted living, hard choices to make for sure but they need help so been working on that instead of the GTM. Would rather be working on the GTM. So, I drive all the way back to Wyoming ad this is what happens the day I arrive, lets us all know winter is coming but I hope it holds off for a little while:
    Oh the Brittany puppy in the picture came home with me from Kansas, I lost my shop buddy some while back a German Shorthaired Pointer I had for years so after a while decided to get new shop buddy. Got a long way to go training her but will be nice especially a night when working in shop by myself.
  33. #272
    Newcastle, Wyoming
    I am going to rework the waterfall engine cover posted earlier as it does not fit right, and I am going to change the color to match the rest of the tunnel. I have issue with where it sits on the tunnel, even though the back matches up as it should, the front small section will not sit all the way down on the tunnel frame. This may be my fault due to where I cut out for the cup holders and fiber glassed the top side. I may have pulled the small nose section up as it sits about 5/8" to 3/4" off the frame even though further down by the cup holders it is sitting on the frame as it should and it matches up with the rest of the engine firewall when installed. Will update when I get a good fix for this problem.
    The fron section is pulled up to match but you can see it is pulled up
  34. #273
    Well, today is the day I put this to the test. I just got this engine started today and everything seems to work well. I have the manual heater core shut-off valve mounted right up by the heater core. Once I got coolant circulating everywhere and was sure that the air was purged out of the heater core, I closed that valve and let the engine cool off over lunch. After lunch the heater core was completely cool, so I fired up the engine again with the valve still closed. The heater core remained completely cold to the touch, and while looking thru the clear part of the donor 'Vette coolant reservoir (which I mounted above the driver's side fuel tank) where the 3/4" and 5/8" heater hoses connect, there is plenty of flow thru there and those hoses get very hot....so I'd say we have plenty of circulation thru the heater core for heat when the valve is open and zero circulation thru the core when the valve is closed....but still plenty of circulation from the 5/8" heater hose to the 3/4" heater hose thru the 3/8" Tee connection. Overall, IMO, this seems to be a great set-up that avoids a lot of complications and connections.
    Shane Vacek
  35. #274
    Newcastle, Wyoming
    Great new Shane, I have the tee's to cut into the lines and install the bypass so guess my next chore it to add the bypass to insure the is flow on both sides of thermostat. Thanks for the update, thought it would work just had not tried it yet.
  36. #275
    Member Lancaster Lad's Avatar
    High Desert, CA
    Attn: VRaptor and James
    Not trying to butt in but did you know Vintage Air has a part #344470 Coyote heater bypass.
    It is H shaped and appears should work in an LS situation. I purchased one but am about
    one year from engine start up but from VRaptor's test it should work.
    Cecil
    PS James I wish my interior would look 1/2 as good as yours but alas no equipment or skill.
    Just to let you know I was born in Lander but left at 1 years old to see the bright lights of Cali.
    MKIV 8851 Complete LS3 376/480 4L70e Auto 2015 IRS 15" Wheels Rear Exhaust
    Ordered 2/25/16 Delivered 3/26/16 Still building 1/1/22
  37. #276
    Newcastle, Wyoming
    Well finally got back to working on the GTM, had an issue with my right leg, getting older really sucks, pulled something behind my knee and could barely walk for a few weeks but better now so back at it.
    Started working on interior again and fitting the rear fire wall, window wall and engine cover. I had it sitting in there in the pictures above, but the engine cover was not sitting down on the 1” tube on the top of the tunnel. And the window wall was just barely touching the intake manifold (not enough clearance) so I had to shim the bottom of the window wall out about ¼” as shown below.
    Once the window wall was shimmed, I reworked the engine cover, wanted to change the color anyway to the same color as the tunnel as it was kind of plain looking and changing the color would give it some contrast. I removed some more foam material allowing the engine cover to come down on the 1” square tube, but when I got it in place it was ¾” lower than the two aluminum pieces on each side of the engine cover. I did not modify the two aluminum pieces and used the factory holes to set my ¼”-20 machine screws that hold it in place. I even had the front piece that covers the tunnel over the gear shift and middle dash section in place to make sure they matched up and were setting in the right place. Below, is what the engine cover looks like installed between the two aluminum pieces and with the ¼-20 screws install on the bottom and held in place. Below is what it looks like in place:
    So I was wondering if anyone else had an issue with the engine cover as I do to get it to sit on down on the 1” square tube on the top of the tunnel? And, I was thinking of leaving it this way as it will be covered in a different color and will add c some contract in shape and color on the rear firewall. Or my other option would be to build-up the engine cover top section to match the two aluminum pieces. I am all ears, and if someone has a better idea or can think of a better option please let me know. I have been looking and trial fitting this section for a while and not going to let it get to me and open for any and all ideas.
    Not sure why if sits like it does on the 1" square tube, or if I have done something with the upholstery or modifications and caused it myself, but here we are and this is what I have to work with now. I am sure I needed to move the bottom of the window wall out a little to make some clearance between it and the intake manifold and I still only have a little clearance between the two now, so it will have to stay where it is out as shown in the pictures. Always something to stretch your imagination building the GTM !!
  38. #277
    Newcastle, Wyoming
    Lancaster Lad,
    Thanks for the information and born in Lander, about 5 hours (300+ Miles) from Newcastle, well bet it is at least some what warmer than here.....we already had a couple of light snows, bet you don't miss this kind of weather at all......
  39. #278
    Indiana
    James,
    My firewall was hitting my intake manifold "beauty cover" so I just deleted the beauty cover. It's only cosmetic with a little sound dampening. You could trim it too.
  40. #279
    Newcastle, Wyoming
    Dave,
    If all that was touching was the beauty cover it would have done the same thing, but with the bottom of the window wall up against the tubing it just barely touches the actual intake manifold. I am not sure if when they built the motor that started out as stock 430HP LS3 to 585HP LS3 they changed the intake manifold or not, it looks stock but when the widow wall is installed per the manual it does touch albeit very lightly, so figured moving it out as shown in picture is a better option than letting it possibly rub against it. Still fighting this section so will go down again today, sit on the stool, look at a while and see it something pop into my head while watching the races.
    Hope your build coming along well and thanks for some of the great ideas you have come up with in conquering your unique challenges.
  41. #280
    Newcastle, Wyoming
    Lancaster Lad,
    Believe it or not, this is my first try at doing the upholstery work on the interior. I did go out and get a sewing machine to sew leather and other interior material but had now experience either. I joined a online class and watched hours and hours of video on how to upholster an auto interior using many different methods. Also spent hours just trying to learning how to sew a straight stich and still struggle with keeping it straight. It take me a long time (am sure someone who is skilled can do it in 1/4 the time) to get it done. Some times have to doe it two or three time to get it right but figured I could learn how to do it as it is no complicated but takes a lot of practice to make it look good. I wanted to as much on the build myself as I could and figured I could learn a new skill as well. Have other collector cars so learning how to do basic upholstery will only help with cost containment when working of them or getting ready for sale. Besides some would say I am a penny pincher and with the cost of an interior around 10K average I figured I could learn how to do this part myself.
    I am sure a professional could do a much better job but with patients, preservice and a lot of trial and error I am making progress and hope to get good at it the longer I keep working at it. If I can do it I am sure almost anyone on this forum can it just take a lot of time and practice.
    The only thing I planned on having an outside shop do is the paint job and maybe the final fine tuning on the body work if mine is not good enough. Like I said I want to be able to say I built this so will try complete myself but if I cannot I will go to get some outside help but going to keep learning and pushing to to the work myself...….just to see if I can, like the challenge
