17
Headlight Aim
The other night I tried aiming my headlights so they point in accordance with the manual, and similar to this article http://www.danielsternlighting.com/tech/aim/aim.html.
However, to get each light to point far enough to the left I have to run the adjustment screw so far out that the trim ring no longer fits over the lip on the bucket. Also, the right side headlight wants to point too high; again, if I bring it down to match the diagram in the manual the trim ring won't fit.
Anybody seen this, and has anybody got any suggestions on how to fix?
MK IV Roadster #8631
