Results 1 to 5 of 5
Thread: SpeedHut Gauges - Another Question
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    One thing I noticed on the bench burn test session... Every gauge does a "wake up" sweep when energized except the Oil Pressure & Water Temp.
    Is this normal, or do I have 2 defective gauges?
    John D. - Minneapolis 'Burbs
    mburger's Avatar
    Punta Gorda FL
    My oil pressure and water temp don't sweep when powered on. My fuel level and volts do.
    Mark
    Senior Member cv2065's Avatar
    Dec 2017
    Quote Originally Posted by Fixit View Post
    What's the best way to bench test John?
    Aug 2017
    Minneapolis 'Burbs
    I've got a regulated output variable DC power supply on my "tinker" bench in the house... I just connected the dash up to it temporarily, and discovered my voltage inverter was DOA.
    You could use a small 12v gel-cell battery (steal it out of the kids PowerWheels or a fish-finder). Just be sure to put a fuse on the + output (5A max)!
    Chino Valley, Arizona
    Just my fuel & volts do the pre-start sweep. The water & oil temp + PSI do not.
