Results 1 to 25 of 25
Thread: What are my side pipe options (replacement)
    I have a set of ceramic coated pipes that I purchased from a forum member. They have rusted through the finish and I’m torn as to what to do. I can have them chromed locally and save a few bucks but knowing myself like I do.... I will not be happy with the finish blueing over time and I will want them record them once they discolor too much. That was my thinking behind get ceramic coated pipes. The finish on these pipes has not held up and is not very shiny.
    What kind of prices are you guys seeing on chroming your side pipes or ceramic coating them.
    Anyone have any input on stainless pipes? I know they are pricey but do they hold up better?
    If it’s part of owning the car, and I get discoloration and need to recoat them every two to 3 years, I can save a ton with chrome being that I can drive 45 minutes to have it done. Ceramic will require shipping two ways and that’s going to add substantially to the cost if I have to continually recoat them.
    I guess what I am asking is... what would you do in my shoes? Should ceramic last longer and be shinier than what I have now? Is chrome a good option? One thing I know for sure is that I love the sound of the factory pipes. I do not want to muffle it any!
    Thanks for any help
    Grand Rapids, MI
    For longevity stainless wins. I have a set from gas-n and they are awesome. Chrome coating is not recommended as exhaust heat will kill the coating and they will still rust if left wet. Ceramic coating is a decent option but kinda pricy. Honestly if you want a solution that is a easy quick fix get gas-n pipes. George also has mounts that come with them that fixes the cracking issue. You can powercoat the mounts as they are steel and mount where the pipes never get hot enough to hurt the coating.
    I was trying to avoid the 1000$ plus expenditure around the holidays. I guess I’ll save up for stainless. I do not like the sound of the gasN pipes. They are too muffled for my liking.
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by GFX2043mtu View Post
    2x this.... Call Georgie, He is great to work with!
    Mar 2013
    Medway, MA
    Mark.... black would not do justice to the rest of my car as it sits! Gotta have some shine to it!
    Jax Beach, FL
    If you don't like discoloration, ceramic is the way to go.
    Chrome - it will discolor and will not last.
    Stainless - It will last. Unfortunately, it doesn't really blue. It nasty gold-browns.
    Not to scare you away, but stainless does this pretty quickly. It does clean up with something called Compound 302. Makes them look brand new with almost no effort.
    Anyone have a picture of the stainless before and after a clean up?
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Another vote for Gas-N’s, very nice pipes with a deeper sound.
    Kyle
    I spoke to Georgie today. Sounds promising. I’m not a fan of the lower rumble. I like the raspier sound of the stock pipes. Now my concern is discoloration of the stainless.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    I have the Gas-N' pipes, but for my car they had to be black. Not offered that way, so I had a local shop blast them with aluminum oxide to remove the polished surface, then coated with a matte black ceramic.
    I like the shape of them, as they have a little longer outlet that has a better turn-down than the original FFR pipes. I preferred the sound of the FFR pipes at anything other than full-throttle, as the slightly deeper tone of these causes a harmonic that seems to bother my ears right around the sweet-spot cruise RPM of 2000 - 2200 at 45 - 50 mph in 4th gear that makes up most of my backroad cruising. A fair trade-off, though, for not killing my hearing at heavier throttle settings - for sure!
    Later,
    Mk3.1 #7074
    Junior Member mefford's Avatar
    May 2018
    NC
    I spliced in flowmaster slimline mufflers 30" in original ffr sidepipes. They have the laminar flow design and they make my sbf sound deep and alot bigger I got a fix it ticket here in ca for the ffr muffler sound level.
    Mk2 challenge car. 347, avenger 209cc cnc head,tfs stg3 cam. 396 rwhp, T5z. Mk4 spindles, koni, 275f/315r r888r. Many mods to chassis.
    Chris, the black looks great on your car. My indigo ink is begging for something shiney.
    Woodstock ,Illinois
    30” Slimlines here... black matte ceramic coating... been loving them for 3 seasons now!
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    JFYI - I traded messages with Georgie the other day, as I'm also considering doing black ceramic-coated Gas-N pipes on my project and he advised that the Gas-N pipes are also available bare (unpolished).
    Port Charlotte, FL
    Another option I don't see mentioned is Quiet Pipes from Boig Motorsports. They sound great and can be ceramic coated. I had my locally coated for $500.
    Henry
    O'Fallon, MO
    I don't think you can have a set of pipes chromed for anywhere near the price of ceramic coating. I think the golden hue on stainless is good looking.
    Raleigh NC, OIB NC
    Quote Originally Posted by Usudno View Post
    About 7,000 miles in this picture. Cleaned a number of times with Wizzards Metal Renew. Wipe it on let it sit wipe it off, no muscle required. Most all stainless steel cleaners should work.
    Starting to go gold will see if I can find a better shot
    A bit more when still very new maybe 50 miles. Lean fuel mix generated heat on dyno runs effected the color. Once its dialed in normally takes quite a while for them to require cleaning.
    Kevin
    MKIV #8234
    Thanks BEAR. I think I’ll go with the gas n pipes. I did take some polish to my ceramic pipes today and it helped the rust not be as prominent. I guess it knocked the surface rust of and just showed the smaller darker area. I probably roll with these for a few months thru the winter then get the gas n pipes installed.
    BadAsp427's Avatar
    Greeneville, TN
    I'm pretty sure that you will really like your GAS-N pipes.... You will also find that Georgie will do everything to make the transaction go smoothly and help you any way he can. I'm all ready convinced I will be getting them as soon as I wear out the SS FF side pipes that I have.
    Oct 2014
    Vermilion, OH
    Another vote for Gas-N. I ordered Georges headers and side pipes for my Kit I'm picking up in January.
    CVOBill
    Yet another vote for Gas-N's. Love the quality, sound, and longevity. Regarding the discoloration or "straw" color that SS pipes can get, depends very much on your engine, lean/rich fuel tune and exhaust temps. I've had Gas-N's on two different SBF/carb builds. Well tuned, but still did get some discoloration. The Compound 302 already mentioned brought them back to new looking, but still was part of ongoing maintenance a couple times a year to keep them that way. The Coyote setup I have on #8674 is in it's second season with nearly 4,000 miles. The discoloration is just barely visible and I haven't touched them since new.
    I’m running really rich right now. Going to have to get that sorted out. Runs good but the wife doesn’t like me starting it in the garage. I usually give it a little push out to keep her happy!
    Rich is "cold" and won't affect the pipes; lean (and slow timing) are hot and will quickly discolor SS or chrome. The golden hue that Paul mentioned is an indication that fuel mixture and timing are correct.
    Jeff, thanks for the clarification. That’s what I thought made since!
