Craig, that might be a viable option to try. I do have the oe cable and like you said the adjuster is just not enough. I don't like where the clutch engages/disengages, which is nearly at the bottom of the pedal travel, I prefer it to be about mid way of the pedal travel. If the other cable with adjustments at the clutch end, that just might be what I'm looking for.
