Thread: Hub bolt size
    Aug 2018
    Hub bolt size
    Does anyone know the size, type and length of the bolts that connect the hub to the spindle. Got the hubs and the spindles but no bolts to connect them. Got most of my POL items last week but didn't know these bolts were missing. I'm starting to make some real progress and hate to lose momentum waiting on a few bolts, I will try to find some locally.
    You need to be a lot more specific. Pretty sure you're talking about the front suspension. Only thing holding the hubs onto the spindles is a large nut that gets torqued to 250 lbs. Like this one: https://cfc7329ad537523a5de1-b21544d...3477a_9479.jpg. But that doesn't sound like what you're asking about. Between the instruction manual and the box inventory list, the bolts are typically defined, e.g. SAE or metric, length, thread pitch, etc. Just be careful. The suspension bolts are all hardened and typically have some type of lock nut, either nylon insert or deformed.
    Aug 2018
    Thanks for the quick reply. No I'm talking about the rear spindle and hub on the irs setup. Unfortunately the paper work only lists the hub and the spindle and the manual doesn't list any bolts or assembly info on that item. The hub inserts into the spindle in a machined hole with a plate on the hub that has four threaded holes that line up with four holes in the spindle. The manual refers to donor rear end not new pieces. It's possible I looked in the wrong place any info will be appreciated.
    Quote Originally Posted by 65kid View Post
    Ok, that makes more sense. I received NIB knuckles/hubs (M-5970-M, drop shipped directly from Ford Performance) for my Coupe build and they were already assembled with the bolts in place. That's why it didn't occur to me. Assumed that's how they always came. Not sure why yours came separate without the bolts. My Roadster build used zero miles donor parts, so of course they were already assembled as well. FWIW, this is what they look like. Flange head metric bolts with an added integral washer. Marked 10.9, so high strength variety. Torqued to 98 ft/lbs. Sorry, can't help with the actual size. I'd be inclined to find the actual Ford part since that's what they're designed for.
    Aug 2018
    yup those are the ones I need, will check with Ford tomorrow. The spindles and hubs came new from f5 all in separate boxes but no bolts. I know it's been said many times before but I must add my gratitude for build threads and your willingness to share your knowledge. Thank you
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I purchased my IRS from Forte's and the hubs came separate from the knuckles. I haven't yet assembled them, so I ran out to the garage to take a look at the bolts. They're M12 x 1.5 60mm long, grade 10.9 with a captive washer. Here are a few photos:
    Aug 2018
    Thanks John that's exactly the info I need. This forum is a wonderful resource.
    Mar 2017
    Norway / Merritt Island FL
    M12, 10.9 has 128 Nm as an average torque value
