Results 1 to 11 of 11
Thread: Roll bar cross member: 1 1/2"
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    Has anyone fabricated their own Roll Bar Cross Member?
    ********** seems to be permanently out of 1 1/2" size. Also I am not sure if ACTON still makes them.
    I know Breeze sells a weldable cross member for their 1 3/4" Roll Bar. But I was interested in fabricating something similar to **********'s with clamp brackets.
    Any thoughts?
    how about one of these?
    https://www.mcmaster.com/=1fqku6g
    Tybee Island, GA
    Craig, dead link.
    Videos are at: YouTube Videos
    Grand Rapids, MI
    I have friends that fabricate and weld. We ordered sticks of 1-1/2" OD, .095" wall 1020 DOM tubing from a local supplier. Cut, bent & welded at the friend's shop. My design, their fabrication skills. Couldn't have done it without them.
    www.mcmaster.com Raw Materials and start selecting what you need.
    Jim
    Another source of metal including DOM round tubing is Online Metalshttps://www.onlinemetals.com/
    Mar 2013
    Fort Collins, Colorado
    I would not use the clamps for this project. Welding the crossbar into the hoop will be far safer.
    I did mine about ten years ago. One thing that will help is to tack weld a sacrificial brace to the bottom of the hoop so that when you weld in the crossbar the heat will not distort the spacing of the legs. After the crossbar is welded and cooled, then cut off the brace.. Not sure if it is required, but it is an easy and quick way to avoid a fitment problem after you are done. This is one of the welds that I had a pro do so that the penetration was up to the task.
    One other thing. the crossbar makes a great place to mount a third brake light. I found a 1 inch high x 10 inch long led that is semi hidden under the wrapped belts and bar. Very visible, it works great without being too obvious.
    Quote Originally Posted by Derald Rice View Post
    Everybody all good information.
    Yes, I am very familiar with McMaster - couldn't do this build without them.
    Derald,
    What is your objection to using clamps?
    Mar 2013
    Quote Originally Posted by Scott Zackowski View Post
    Derald,
    In my opinion the clamps are a weak link. I know that they are convenient, and if you have a chrome roll bar, I can appreciate the reluctance to weld on it. But a fishmouthed DOM tube that is welded by a competent welder will bend before the welds break, and that is what I am betting my life on.
    Now lets talk about the belt attachment method. Some of the clamp on bars have eye bolts to snap the harness into, instead of wrapping the belts. Now the clamps may not be the weak link, but the eye bolts are. And those eye bolts are aimed at the back of your head. Sort of like russian roulette.
    Now, go look at any sanctioning body's rulebook. I don't think that you will find any of them allow clamp on harness bars in classes where a harness is required.
    Derald.
    Derald.
    Much better link.
    Very interesting!
