Results 1 to 4 of 4
Thread: 351 w Fuel injection
    Dec 2018
    Hey guys anyone running this set up? Thinking about this intake for my 351W
    https://www.ebay.com/itm/Ford-351W-W...!-1:rk:20:pf:0
    Maricopa AZ
    You will need to do a bunch of grinding to clearance the intake to clear the dizzy. I have also found if you re running an aggressive cam profile the sportsman ECU works better.
    I would also check w/ Wayne here
    http://verycoolparts.com/index.htm
    Member ChasNMe's Avatar
    Sep 2018
    Charleston, SC
    i thought about doing stacks also but haven't seen anyone with a clean way of doing air filters with them . . . .
