Likes Likes:  4
Results 1 to 19 of 19
Thread: Looking for info on changing over to EFI stacks. Any info appreciated.
    I知 toying with the idea of converting to efi stacks from my carb壇 setup. This is just an idea and far from actual execution but I was wondering if anyone had made the swap and what all did it require. I知 currently running a mechanical fuel pump and a quick fuel HR 650 on my Tristar Performance 351W.
    I知 trying to wrap my head around issues that I may run into.
    Wiring issues (after the fact)
    Ignition issues
    Fuel line issues (mechanical pump/ no return line)
    Sensor issues
    Can anyone recommend a 徒it that may address many of these issues? Also do most systems come with a base tune to get things going? I have someone locally that tunes modern fuel inkected cars and I知 sure he could tackle the fine tuning of mine if asked.
    Thanks for any help. I truly appreciate it.
  3. Likes MVRight liked this post
    Wow, that website is nearly impossible to navigate! I see a set of stacks... I guess I’ll shoot him a message.
    Manchester, MD
    Yes, call or email - he's very good about responding.
  6. Likes chuckster liked this post
  7. #5
    Sherwood Park, Alberta
    I have both the Inglese 8 Stack and the Borla/Weber 48 Stacks and love them both. The Borla set up is much more original and some nice eye candy. Throttle response is great, but the real reason for me was pure looks.
    Both were retro fits and I think you are looking at a complete redo of plumbing, fuel management, O2 sensors etc...
    Most important is to have somebody you trust to fine tune the system.
    " The journey is the reward" Chinese Proverb
    FFR Roadster #5380
    FFR Spyder GT #030
  8. #6
    I have someone capable of doing the fine tuning. They are in Lake Charles but its just an hour or so away. Like I said previously, this is just the beginning stages as of right now.
  9. #7
    Gordon Levy's Avatar
    Maricopa AZ
    I am a dealer for Borla, Eightstack and Inglese and do probably 10 systems a year. Please feel free to give me a call and I would be happy to help you through everything you need to install a system.
    Go Fast Part and tech Specialist [email protected]
    http://www.facebook.com/levyracing www.levyracing.com
    Completed over 215 FFR builds in the last 23 years and still counting
  10. #8
    Chapel Hill, NC
    Trust me, just talk with Wayne!
    Don't let the website throw you, everything he does is first rate! Give him a call, and he will walk you through everything you need to do to make the swap. Many folks here have used Wayne for a variety of challenges, and he does a great job, and takes very good care of you! Even if you end up not making the swap, you will know exactly what you need to do with Wayne's guidance.
    Good luck with whatever you decide.
    Santa Clarita, CA.
    Read this article before you go out and drop $6K plus on eight stack injection. Luckily I still have the money I saved for the conversion sitting safely in my safe until I find a system that truly works for my application. So far Im sticking with what I have. I think eight stack looks amazing but unless you are just racing I am not sure you will be happy.
    http://www.badasscars.com/index.cfm/...rod/prd400.htm
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
  12. Thanks CobraboyDR thanked for this post
    Likes CobraboyDR liked this post
  13. #10
    Dec 2018
    Quote Originally Posted by CDXXVII View Post
    Good article.... Makes sense
  14. #11
    I read the article. I think the efi systems are much less temperamental.
  15. #12
    Bonney Lake, Washington
    Good read - thanks!
  16. #13
    Quote Originally Posted by Gordon Levy View Post
    Gordon, do you have a personal preference between the three?
  17. #14
    Maricopa AZ
    Depends on the look and performance you are after. The eightstack looks very original and is easy to plumb and works great up to 500hp. The borla will support 600hp and you can get K&N air cleaners for it where the eightstack you have to use the strainer type filter. The pics earlier in the thread are of the Inglese and the eightstack. We installed both of those. There is probably a $500 price difference betwene the 3. That is important is the ecu system used. That really depends on how aggressive your engine is cammed. For stuff pretty mild a FAST EZ 2.0 works pretty good. Anything more aggressive I would really do a programmable sportsman ECU.
  18. #15
    Thanks Gordon!
  19. #16
    Jax Beach, FL
    The stacks with strainers or no filter at all are the best looking, to the point of making me drool. Why is it that the best looking stuff is always the most expensive and the hardest to live with?
    Cars and women.................
  20. Likes cgundermann liked this post
  21. #17
    O'Fallon, MO
    DO NOT, DO NOT use a Fast EZ 2.0 with a Borla stack system, IT WILL NOT be tunable. Thats what I was sold, and I got screwed. There was no way to make that system drivable. After spending a boat load of money at 2 different shops trying, and sending the computer back to Fast 2 times, the Fast tech's finally admitted that "well that computer won't work, you should have at a minimum a Fast XFI Sportsman".
  22. #18
    Member PaulProe's Avatar
    Manchester, MO
    My FE EightStack system with Performance Electronics ECU works without issues. Highly recommended
  23. #19
    Colorado Springs
    On a 427W. Run by a Megasquirt computer. Ran excellent on pump gas or E-85. Purred like a kitten around town. But hit the skinny pedal, and it would scream like a banshee and take off like a rocket.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42
    FFR MII: Dart 427W, Momar 8 stack EFI, Tremeac TKO, IRS, Red with Ghost Flames, 600'ish HP.
    -- Gone, but never forgotten
    www.RacingTheExocet.com
Legend Lines
