Likes Likes:  3
Results 1 to 11 of 11
Thread: Touch Screen Audio/Video System
    Senior Member MBB Larry's Avatar
    Feb 2018
    Grapevine, Texas USA
    With the Limited Visibility, I was thinking of installing a Dual Camera (Front and Rear) to assist with Parking etc. Crutchfield said this system will support 2-Cameras. Also for Audio/Nav/Phone etc. Has anyone installed a Camera System to you car??
    FFR Hot Rod #1106
    Oct 2014
    Vermilion, OH
    I have a Kenwood touch screen radio with back up camera, navigation, phone etc. in my Hot Rod. The back up camera helps a lot when I have the convertible top up. IMG_2021 - Copy.JPG
    CVOBill
  3. Thanks wrp thanked for this post
    Likes wrp liked this post
    Jun 2018
    North Vancouver, BC, Canada
    Was thinking along the same lines Larry. I was only concerned about a rear camera though and quite a few systems will take 1 camera. Had been looking at the Pioneer line up.
  5. Likes AJT '33 liked this post
  6. #4
    Feb 2018
    Do you know if it will work with 2-Cameras?? I concerned with Parking and Texas Roads. One in the Rear for backing out, and one for the Nose. It is way out there and low.
    FFR Hot Rod #1106
  7. #5
    Feb 2018
    Do you know if it will work with 2-Cameras?? I concerned with Parking and Texas Roads. One in the Rear for backing out, and one for the Nose. It is way out there and low. Is it very deep?
    FFR Hot Rod #1106
  8. #6
    Senior Member JOP33's Avatar
    Haslet, Texas
    Quote Originally Posted by CVOBill View Post
    Mind me asking where you mounted speakers and quantity?
  9. #7
    Haslet, Texas
    Quote Originally Posted by MBB Larry View Post
    Larry - I agree. I don't know that I will ever use it, but I am thinking a front facing camera mounted right behind the grill as well. I am sure that in most cases by the time I see anything it will be too late to react, however it is one of those things I would rather have and not need than need and not have. The thing I struggle with the most is where to place a screen that is large enough for my vision but subtle enough to not look like a media room!
  10. #8
    Oct 2014
    Vermilion, OH
    [QUOTE=JOP33;348963]Mind me asking where you mounted speakers and quantity?
    I have two speakers in each door panel. I started with one in each door panel and realized the GPS "talks" in the front speakers only. The good part is I thought a head and ran the wires into the door for front speakers if I every wanted/needed them.
    CVOBill
  11. #9
    Oct 2014
    Vermilion, OH
    Larry, yes the radio I have will support two cameras.
    CVOBill
  12. #10
    Does anyone know of a radio system that would support 3 cameras. reason I ask is I have been looking at RV parking cameras and screens? I am trying not to run side mirrors and rear view mirror. I want a shaved side look. No door handles and mirrors. Looking to mount mini cameras on the sides and the rear to substitute the mirrors
  13. #11
    Haslet, Texas
    Quote Originally Posted by JEMAN View Post
    I like the concept (shaved), however you may want to check on the legalities of no mirrors. I could be wrong (as in most cases I am), but I believe most states require at least a drivers side mirror and then if the rear window is blocked a passenger side mirror as well. Please don't take this as gospel, but do check.
  14. Likes AJT '33 liked this post
