Thread: 818 gauges
    Senior Member Hojo's Avatar
    Apr 2018
    Springfield MA
    818 gauges
    I have decided to use Zero Decibel’s dash bezel. Therefore, I will have 4 52mm spots to fill. Now I need to choose the 4 and the brand and model while knowing very little. So far I’ve seen the following in the forum:
    Boost
    Oil pressure
    Oil temp
    Exhaust gas temp
    Air fuel ratio
    Voltage
    Other?
    I have a JDM EJ20 motor and will be using iWire but can’t use Cobb because of the JDM.
    If you were to pick 4 with what you know now what would they be?
  2. Likes Kiwi Dave liked this post
    Mar 2014
    Hingham, MA
    Quote Originally Posted by Hojo View Post
    Boost
    Oil pressure
    Oil temp
    Exhaust gas temp
    Air fuel ratio
    Voltage
    Other?
    I have AutoMeter Oil pressure, Boost and Volts. If I were to add one more it would be oil temp. See attached photo. If you are able to stop by (see PM) You are welcome. 818 dash.JPG
    Leesburg, VA
    Boost
    Air-fuel ratio
    Oil pressure
    Oil Temp
    I'm using Prosport gauges for oil pressure and temp. The AFR gauge is made by AEM because I needed the serial output for data logging.
    Apr 2018
    Springfield MA
    One last bump before I order my gauges.
    Senior Member DSR-3's Avatar
    San Jose, CA
    I can't comment on the functions, as I have a whole different animal. But for the 2 that I did use (clock, fuel) I've been happy with the look and quality of Speedhut products. I used the Revolution line.
