818 gauges
I have decided to use Zero Decibel’s dash bezel. Therefore, I will have 4 52mm spots to fill. Now I need to choose the 4 and the brand and model while knowing very little. So far I’ve seen the following in the forum:
Boost
Oil pressure
Oil temp
Exhaust gas temp
Air fuel ratio
Voltage
Other?
I have a JDM EJ20 motor and will be using iWire but can’t use Cobb because of the JDM.
If you were to pick 4 with what you know now what would they be?
Originally Posted by
Hojo
Boost
Oil pressure
Oil temp
Exhaust gas temp
Air fuel ratio
Voltage
Other?
I have AutoMeter Oil pressure, Boost and Volts. If I were to add one more it would be oil temp. See attached photo. If you are able to stop by (see PM) You are welcome. 818 dash.JPG
Boost
Air-fuel ratio
Oil pressure
Oil Temp
I'm using Prosport gauges for oil pressure and temp. The AFR gauge is made by AEM because I needed the serial output for data logging.
One last bump before I order my gauges.
I can't comment on the functions, as I have a whole different animal. But for the 2 that I did use (clock, fuel) I've been happy with the look and quality of Speedhut products. I used the Revolution line.
