The Traveling Builder
Results 1 to 4 of 4
Thread: 2004 Hydroboost question
    Dec 2017
    All,
    Installing a remanufactured hydrobooster and MC using a 2004 Mach1 pedal box. Its obvious how they bolt together, but internally there is nothing to apply the booster brake pressure to the MC. Assuming there is supposed to be a rod/plunger in there somewhere to connect the two? I've been searching, and haven't found a diagram or picture of what actually connects the two. Lots of images of them together and apart, but nothing concerning what is in between them. Hope this makes sense. Sorry for the rotated photo. Forum software is rotating all my vertical pix to horizontal.
    Yes, there is a pushrod between the hydroboost unit and the MC. I can't comment about your specific parts, but I did do a setup like this on my #7750 Roadster build. Mine came from Forte and I had to adjust the pushrod length. It's been several years ago, and I can't find the specifics. But there was a spec for the amount of play with both units seated. Too loose will affect how the brakes work. Too tight could make the brakes drag or not bleed properly (my situation). Also some units have springs, cups, etc. as part of the pushrod setup. This picture is an idea, but is before I adjusted the length. Here it's too long. Hopefully that's enough breadcrumbs to get you started.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
  3. Thanks erstanl thanked for this post
    Dec 2017
    edwardb,
    Thanks! that does help, and I shall continue the search for this part.
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    I bought an NOS Ford replacement hydrobooster from Max at Five Star Ford years ago, it came fully assembled with an output pushrod. From what I've heard, the remanufactured units commonly come without an output pushrod. Sorry, I hope its not a major PIA to slip it in there!!
    Sean
    MK 3.5 (MK IV body retrofit to MK III chassis), 351W stroked & poked to 396 c.i., custom EFI, 4 into 4's, 3link, 3.73, 15" Halibrand replicas, full bumpers, 2 X roll bars, IČ electronics, hydroboost, 5-lug, GT front, MK VIII/Cobra rear discs, Levy rear LCA's, Forte front bar, VPM rear bar, painted by SRP (again!)
