Results 1 to 3 of 3
Thread: Forte Hydro CLutch set up
    Lake Mills, WI
    Guys,
    Just assembled the transmission and motor. 5.0 coyote, TKO600 and steel quick time bellhousing.
    Take a look at these photos. Does this seem correct? Doesn't seem to have enough room to get it to fit or function.
    Do I need to disassemble the transmission and Bellhousing to readjust the pivot ball?
    Thanks in advance for your input and thoughts.
    Martin
    Lake Mills, WI
    PS, I know the Aluminum spacers are not in the photo, but is the clutch fork to far to the rear of the car. Its about 1/16" away from the back of the bellhousing.
    Something is way off. Either the pivot, or maybe the TOB isn't on the arm correctly? You want it tipped toward the back slightly, but there should be a decent gap behind the arm. Like this picture I sent in a PM. Same exact parts.
