Results 1 to 10 of 10
Thread: New Series 1 Mendeola - What's all needed?
    I've been trying to find some info on this and thought maybe it could be consolidated. Being in Canada I need to try and round as much as I can to get it to the border to get it all in one shot.
    Im going to be using a LS7 w/ intake and Kooks headers. Maybe a small cam too.
    Clutch. Standard Ls flywheel/clutch/pressure plate.
    Pilot bearing, standard LS Gm?
    Slave cylinder provided by Mendeola. What will be the best MC size to use as I dont have these yet? What is the end fitting?
    Starter - confirmed to be the IMI 140 and needs cleareancing/heat wrap. Seperate post stated MSD won't work.
    CVs - what is needed?
    Reverse Switch - included ?
    VSS - Mount or location provided?
    Shifter - Sold by FFR? Mendeola? Est costs?
    Mounting - will it bolt to existing mounting points?
    When I ordered my GTM I stated I was using the mendeola. What is included from ffr vs the porsche box?
    Missing anything?
    Thanks for any info on this.
    Member Mendeola Transaxles's Avatar
    Quote Originally Posted by Dj22 View Post
    Clutch.
    Flywheel is a LS1/LS6 flat friction surface
    JEGS# 601260 1997-2004 GM LS1/LS6 Flywheel
    Chevrolet Flywheels
    Fits 5.7L LS1/LS6
    Utilizes 11.0" Clutch
    168-Tooth, 14-1/8" Diameter Ring Gear
    24.4 lb. Total Weight
    Replaces GM 12554130N
    1997-2004 Corvette
    1998-2002 Camaro/Firebird
    Pressure plate & clutch disc is a unit to fit above flywheel
    Examples:
    Kennedy Engineering part# KEP-S11/KEP-GMP11 with GM 26 spline, sprung hub street disk & stage 1 plate
    SPEC Stage 1 clutch kit, SPEC part number SC091
    SPEC Stage 2 clutch kit, SPEC part number SC092
    EXEDY clutch kit and flywheel package part #04173
    Pilot bearing, standard LS Gm? Yes, Standard GM pilot bearing
    Slave cylinder provided by Mendeola. Yes, 7/8" bore.
    Maximum travel 1 1/8".
    3/4 is standard unit from what I understand from FFR manual.
    Whatever MC is used we recommend an adjustable clutch pedal stop.
    3/16" standard American brake line fitting
    Correct
    1976-1984 Porsche 911 Turbo 40mm Wide CV joints
    Part #: 93033203400
    Reverse Switch - included ? Included
    VSS - Mount or location provided? Yes
    Shifter - Sold by FFR? Mendeola? Est costs? FFR is providing Information and mounting of this unit.
    Mounting - will it bolt to existing mounting points? FFR will provide mounting brackets.
    When I ordered my GTM I stated I was using the mendeola. What is included from ffr vs the porsche box? FFr should be providing everything to bolt the unit in.
    Missing anything?
    Breather box
    oil cooling/circulation system
    temp. gauge and sender
    10mm x 1.50 bolts for CV's
    FFR should be able to answer all these questions for customers.
    We are available here on this site and can be reached at 619-710-8800 ext.109
    Thank you
    This is great information! Can you provide the information pertaining to the LS3 E-Rod engine and what would be different?
    Thanks so much.
    Quote Originally Posted by Mendeola Transaxles View Post
    Thank you
    Quote Originally Posted by Radkat View Post
    Thanks so much.
    This information will pertain to all GM LS1-LS7 based units.
    Thanks so much, that's great.
    Good information. I was told that the stock GM starter should also work with stock headers, is this true?
    Quote Originally Posted by dreabrown View Post
    No, due to the bellhousing configuration it can only use the IMI-140 at present time.
    San Diego
    Correct CV Kits can be found here:
    http://myraceshop.com/930_CVs.html
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Thanks for the quick reply and all the info. Good thing I didn't order that Ls7 clutch setup.
    Can't wait to see this. You still owe me a shipping quote up to the canadian Abyss thou.
