0
Noob to Coyote question - Wiring harness on the engine from Ford
The Ford harness that comes on the crate engine has a connector for the (factory) Oil Pressure sender.
This sender is replaced with whichever sender your FFR gauges require.
Question is:
Does the Ford ECU/ECM/Magic Black Box engine computer require an oil pressure input?
Also, I'm assuming the ECU gets an engine temp signal from another sensor on the block?
John D. - Minneapolis 'Burbs
