For nearly everything, you could get along with a 1/2-inch drive that goes to at least 100 - 120 ft/lbs. Couple of the suspension bolts are in that range, most are less. The front hubs, and rear if you're doing IRS, require 250 ft/lbs and are the only ones in that range. You could buy one, or borrow if you know someone or get from a local parts store from their free rental program. If you're doing Wilwood brakes with the 2-piece rotor, they're held on with a bunch of small screws that have an in/lb torque that's below the typical 3/8 or 1/2 inch drive models.
Something else to consider. More and more torques as listed as xx ft/lbs (or in/lbs) and then so many degrees additional. So called torque-to-yield fasteners. Not many on the build, but they're there. You can eyeball them, but there are angle gauges made for that purpose as well.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
