Thread: Part ID.
    Accord NY
    Part ID.
    Can some wha5 tell me what this for? It came with my roadster kit.
  2. Thanks BadAsp427 thanked for this post
    BadAsp427's Avatar
    Greeneville, TN
    The fittings seem to be for your brake system. I don't know about the spacer looking thing. It almost looks like the items you may need to install a Master Cylinder of some kind or power brakes?????
    Check your inventory for the 13691 part number. It should provide a line item for each part in that bag and will also identify what system it is part of if it is listed under a larger section. I agree with Carl that the fittings look like brake fittings, but the machined part is not something that my kit came with. It looks like it could be a mounting ring for the brake fluid reservoir???
    Bakersfield, CA
    Looks like a muffler bearing and some adapters to change your piston return spring rate.
    Kurt
    Build thread
    Bakersfield, CA
    Sorry, I just had to lol
    IMHO I believe it’s a hydroboast adapter kit. Thus like Dave said, brake fittings.
    Kurt
    Build thread
    Norton, MA USA earth
    The aluminum adapter is for mounting the Hydraboost system to the fire wall. Maybe you ordered the 4.6 donor package?
    Accord NY
    Thanks Mike. I did order the 4.6 donor package. I tried finding the number on my parts list but was never able to find it. To many numbers and might be missing a page by know.
