10-14-2019, 09:25 PM
#361
Originally Posted by
GTBradley
Yeah, don't break your glass!
Other than that follow everything you said to me. It's all been straight forward, just a lot of trips to the DMV and a couple to the State Patrol. They will give you a two day temp tag to go to the inspection just don't go to get it until you are within the 2 two day window of your appointment - which you set on-line, BTW.
Cool. All my paperwork is filled out and ready to go. When my car gets back next week, I'll need to install the Simpsons and it should be ready to inspect. I'll take the required pictures and add them to the packet, but that should be all I need to do. My DMV is in Kiowa, forty-five minutes away, so "a lot of trips" is going to be a pain. Not to mention that the Elbert County DMV isn't open on Fridays.
Did you get a two-day temp tag for both trips the CSP in Castle Rock?
10-14-2019, 10:06 PM
#362
Colorado Registration Process - Arapahoe County
Two of the trips were really not necessary. The first was early on to get info that I already had access to on-line. The second was to pick up the two-day tag. I went in late on a Friday to get it for my Tuesday CSP appointment and was told to come back Monday - what they do if you have a Monday morning appointment with the CSP, I don’t know. I have only been to the CSP once so far, when they call soon for the VIN plate attachment I’ll go on my 60-day tag. BTW, the DMV did not offer the 60-day tag (actually written for 58 days) I asked for it once the paperwork was complete. I’m not even sure it’s officially supposed to be done - maybe a box of sprinkle doughnuts would help.
So you could set your CSP appointment on-line and then go in to the DMV the day before the appointment to get the paperwork done, pay sales tax and get your two-day tag at the same time. The next day do the safety inspection appointment at the CSP and drive right back to the DMV with your approval paperwork and ask for the 60-day tag then. That would ideally cut it to two DMV visits and one CSP visit in two days. Technically, you could do all those in the same day, but that would be tight. Once the approval comes, the point I’m at now, you need to go to a special location for having the VIN plate affixed, I think mine might be in Golden. Then back to the DMV for the final paperwork and to pay the registration fee, plus another temp tag. This is the time to request the personalized plates. The license plates will come in the mail a month or so later.
Bradley
10-14-2019, 11:26 PM
#363
Howdy!
What kind of garage flooring company did you go with there? Thanks!
Fixit
Agree w/ Edwardb on the engine stand... you won't need it for the jobs ahead of you.
The Coyote comes bolted to a pretty stout wood cradle assembly from Ford. The crate/box framing is just tacked to it with a zillion nails.
Attachment 99084
Some careful work with a prybar will get rid of the 2x4's, and you'll have a really nice cradle in minutes. Lift the engine up and set it on a furniture dolly and you're good to go.
Attachment 99085
I installed the oil pan with the engine hanging from the hoist. Just follow the safety rules and DON'T GET UNDER THE LOAD. It's not a bad job. When it's hanging there you'll need to take some measurements and do some carpentry on the Ford wood cradle. Lower the engine back down, and start on clutch/transmission.
Attachment 99086
10-24-2019, 10:37 AM
#364
Well that figures, the Colorado State Patrol called this morning. They say I can come in now to get my VIN plate installed...
Bradley
10-27-2019, 11:35 AM
#365
VIN plate installed
Saturday was the perfect day. I got my VIN plate installed and drove all over the front range plaines. Including dropping in on Dave(papa) to to see his beautiful new Cobra.
Bradley
Post Thanks / Like - 0 Thanks, 3 Likes
10-27-2019, 08:01 PM
#366
Badges
It snowed all day today so I spent time on the car. I got my Cobra nose, trunk and steering wheel badges installed. I committed fully as I did use the pins and push on speed nuts.
Bradley
10-27-2019, 08:04 PM
#367
GTBradley
Nice picture on your way out of my neighborhood!
10-27-2019, 08:08 PM
#368
Papa
Isn't it? I even pulled over to take it. Too bad there are so many bugs on the windscreen. Oh well, you can’t have a clean car and drive it too.
Bradley
11-02-2019, 07:45 PM
#369
Radiator Protection
I spent some time this week looking at options for dressing up the radiator. I like the look of the honeycomb product from Allstar/Amazon, but I wasn't sure how to attach it and more importantly how to remove it later for easy cleaning and replacement. I painted the radiator screen with black spray paint and zip tied it through the fins of the radiator just to try it out. It works great and looks nice. I finally landed on some Z bar from Amazon to hold it in place.
First I removed the rivets holding the lower radiator shroud
...then put the z bar under the lower radiator shroud and riveted it back in.
It's hard to see the z bar but it's there
Bradley
11-02-2019, 07:49 PM
#370
The idea was to have a channel for the honeycomb to be held in place and be able to remove the top channel easily to clean or replace it without a lot of work. The honeycomb product by itself doesn't look very good on the edges and it's hard to cut with a perfectly straight line.
Edit: as it turns out, the Honeycomb bends enough to come out without removing the Z-channel and only takes seconds. The product I used was "Allstar ALL30158 19" High x 26" Wide x 1/2 Thick Honeycomb Design Radiator Screen"
Bradley
11-02-2019, 07:51 PM
#371
The z bar is simply bolted in across the top with the two bolts holding the Breeze radiator shroud in place
Bradley
11-02-2019, 07:53 PM
#372
So now everything looks clean and is simple to remove when needed
If you're wondering about the sides, it turns out the radiator fins are recessed from the side tanks and that captures it quite well. I took a high-speed test run this afternoon and the grill protection stayed in place.
Bradley
11-02-2019, 10:35 PM
#373
Agree with you on the honeycomb edges. Looks like you came up with a great idea to finish it off. Great pictures of your drive. Sun on the horizon is nice. I can't wait to have the same view!
11-04-2019, 01:06 AM
#374
cv2065
It looks like you’ll be there soon enough. I don’t know if you’ve ever driven one before, but I hadn’t and it is truly thrilling. It’s worth the wait.
Bradley
11-04-2019, 10:44 PM
#375
GTBradley
Thanks. I saw Ken Miles' car at the Shelby American Museum in Boulder, Colorado and said "I like that". Later I dumbed it down to "what will make people remember that car they saw back in the 60's, the one that made them think "I'm gonna have that car some day".
Nailed it!
11-21-2019, 11:08 PM
#376
Fan Controller to Reduce Fan Run-Time and Noise
This is for those guys out there that have a loud radiator fan and want to quiet things down a bit. I hear lots of other engines use this very thing, not just the Coyote.
I have a real problem with the decibel level of my Factory Five supplied radiator fan, actually it comes from Maradyne. It appears to be a very good and capable cooling fan, but controlled by the Coyote computer, it ends up running all the time at full power. At 225 watts it amounts to some significant energy wasted too, especially considering this thing runs even at highway speeds - what is the sense in that? Once it's on it won't shut off even if the engine gets cool, not until the ignition is shut off. Mine would typically turn on no later than 80 degrees C, and sometimes as low as 75. The thermostat hasn't even opened at those temps!
This is an unfortunate design and reportedly it is this way because Ford was concerned that they didn't know what conditions these crate engines would be operating under, so they decided to err on the side of caution, as in, turn it on when the engine is on, run it at full speed and make it stay on. I know it is an inferred temperature that the computer determines based on sensors in the engine, but that fan has only an indirect relationship to the engine temp. What the fan affects directly is the radiator and keeping the radiator cool obviously keeps the engine cool. So why not control the fan based on radiator temperature? Or better yet the coolant temp just before it re-enters the engine?
What I did to address this was to install a coolant sensor in the lower radiator return hose and fed that information to a Pulse Width Modulated fan controller. BTW, Maradyne makes the only one I could find that operates at half-speed and kicks into high when needed.
Controller part number MFA136. Sensor adapter is from Amazon Check what your radiator hose size is though, as I’ve heard from others that they needed a 40mm adapter.
The controller mounted nicely to the right side inner wheel panel (elephant ear) and the sensor wires were routed along the back of the fan. The controller is currently powered by the Coyote fan wire, but I'm considering changing to the battery. The thing is, the controller will run for an additional minute after the ignition is shut of at low speed, but not if powered the way I have it now.
In the video you'll see LEDs on the controller. At first the red LED is the only one lit and that means that ignition power has been turned on. After a few seconds the green LED lights up and you can hear the fan blowing at half speed. The center LED is yellow and it will light up when the fan is running at full speed, but that didn't happen in the video.
The fan runs significantly less than it used to and it runs at half speed when it does in these cool Fall temps. I set the on temp at 90ish degrees C, which means the fan doesn't come on at all at low driving speeds and in 50 to 60 degree F weather. It will come on when idling for extended periods, but it is quiet and very acceptable to me now. I love hearing the the pipes at idle rather than an industrial sounding fan.
Bradley
11-22-2019, 08:48 PM
#377
Cobra completion.
I'm nearing the end of my build thread, as I really don't have much more to add, either to the thread or the car. I know these projects go on forever, but I'll go ahead and say here that the car is finished. I think what I'll do next is post a graduation thread.
It was almost exactly 11 months ago that I started this thread. I received the kit the day after Christmas and started on inventory the first of January. The first start was late April and go-kart in early May. Delivery to paint in mid-June and pick up from paint mid-September. The licensing stretched out for more than a month, but I got my personalized plate (see my avatar) on the same day as the Ford V Ferrari movie debut. I declared the car complete, nick-named it Miles and proudly drove it to the Shelby American Collection Museum in Boulder and then the Ford V Ferrari movie just last Saturday. It creates a crowd of the friendliest people almost everywhere I stop. This whole thing has been a whirlwind and I can't believe what I own now.
Thanks to everyone who posted here and for all the technical input, encouragement and compliments. I don't know where I'd be right now if it weren't for you guys - certainly not on the road. Don't hesitate to contact me if you new builders reading this need any help.
See you all on the road and at the car shows.
Bradley.
Bradley
11-22-2019, 10:14 PM
#378
Congrats, Bradley! What a beautiful car - you've done a great job!
11-22-2019, 11:49 PM
#379
PeteMeindl
Thanks Pete, that mans a lot coming from a guy as meticulous as you.
Bradley
11-23-2019, 08:38 AM
#380
I love the car, the nick-name and the license plate. Well done.
11-23-2019, 09:16 AM
#381
I love the license plate! Very creative. The car looks great in your pictures, but having seen it in person, the pictures don't do it justice. Looking forward to getting together for a drive this summer.
11-23-2019, 02:44 PM
#382
Right On Bradley! Congratulations on a nice build and a beautiful car. I like that you found a different way to do some things... unique and original. Nice work.
11-23-2019, 09:32 PM
#383
Thanks Steve, Dave and Boyd. I’m honored to to be associated with builders such as yourselves.
Bradley
12-17-2019, 10:03 PM
#384
License Plate Mod
The continuation of this build thread will be about upgrades and mods that are post build-completion. My first one is the license plate mod, I know it isn't really an upgrade, but I wanted to get in here as I've seen this done a lot on the forums, but never really saw the detail I wanted.
I decided to do the plate cut at the top because the Colorado state name is at the bottom. If it hadn't been, I probably would have drilled the hole in the plate at the bottom for the handle.
I started with a template of the light box where it contacts the trunk lid.
I don't remember if the holes were pre-drilled from FF or if the painter drilled them, but they were too low, so I made a template from cardboard for drilling new ones higher up.
After mounting the light in the new mounting holes, I measured for the depth of cut I would need in the license plate and also the width. I did, ultimately, widen the cut beyond what is shown here
Bradley
12-17-2019, 10:13 PM
#385
12-17-2019, 10:29 PM
#386
It's a nice work-around, though I still wish I had the new trunk lid that doesn't need this level of modification.
I just wish he were alive to see it.
Bradley
12-18-2019, 09:09 AM
#387
GTBradley,
I've seen some really cool license plates in my days and yours rates right in top, with a such a really cool and clever way to convey a message using only 7 letters & numbers. Nicely done!
Dj
12-18-2019, 04:36 PM
#388
ydousurf
GTBradley,
Dj
Thanks, I only thought for 4 or 5 months before coming up with it. I had a long list with some really dumb stuff on it and a good short list, but this one won out in the end. My other Shelby plate was going to be IOUSHLB.
Bradley
12-19-2019, 11:57 PM
#389
12-20-2019, 12:01 AM
#390
12-20-2019, 09:58 AM
#391
Nice job, Bradley. I plan to do the same task with the same anchors this weekend.
12-20-2019, 10:20 PM
#392
Papa
Hands down easiest/most effective thing I’ve done on the car, Dave.
Bradley
12-21-2019, 08:34 AM
#393
GTBradley
That was cool. I didn't see that on Dave's thread. Thanks!
12-21-2019, 12:18 PM
#394
He hasn’t done it yet, though he probably is working on it at this very moment (instead of cruising on 65 degree day DAVE). He did the legwork and posted it here and there, though.
Bradley
12-21-2019, 12:31 PM
#395
GTBradley
No driving yet. I'll have a ten-day temp tag on Monday and you better believe I'll be on the road if the weather is anything close to what we have today. My tasks for this weekend are to install the anchors in my floor mats and to polish and install my aluminum spats from VeryCoolParts.com. The spats are a very nice heavy aluminum and formed with an English Wheel to the shape of the MK4.
12-21-2019, 12:52 PM
#396
That’s good news Dave. I did buy the clear spats and will put them on today. I’ll be interested to see how your metal ones work out. I don’t do much driving on your type of road, so in 1000 miles I really haven’t had and chips show up yet, even unprotected - I’m hoping the cheap ones will do the trick.
Bradley
12-22-2019, 03:54 PM
#397
12-26-2019, 06:50 PM
#398
Clutch cable
This won't qualify for an upgrade post, but is more of a repair post. I really didn’t expect this to happen so soon
Bradley
12-26-2019, 06:54 PM
#399
12-26-2019, 07:05 PM
#400
Clutch Cable Repair and Upgrade
I have been happily driving my new Cobra Mk4 roadster every chance I get. I check it over on a regular basis, but really haven’t found any abnormal wear items or issues of real concern. The Coyote engine is rock solid and everything else works great. So I’ve started to forget about the possibility of a breakdown...until Monday when my clutch cable snapped! Luckily, my long country drive out in the “boonies” Sunday was uneventful, but the next day I drove about 15 miles to a tuner shop and when I was backing out of my parking spot I heard a loud pop and the car lurched to a dead stop, the clutch pedal all floppy.
Gotta give it to my insurance company, Hagerty, they’re a little more expensive than others, but they came through for me. I had a flatbed tow truck in thirty minutes and I was home in no time at no cost.
If you look closely at the picture you can probably figure out that it was my own fault the cable broke.
Bradley
