Thanks Thanks:  44
Likes Likes:  161
Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 654
Thread: GTBradley's build - Still Kick'n!
    Nov 2018
    Centennial, CO
    Body and panels are off.
    I built a lightweight/small dolly for the stages before the kit gets heavy and it works pretty well.
    Bradley
    Nov 2018
    Centennial, CO
    Control Arms
    I installed the control arms with some difficulty. I'm pretty sure they are correct now, but the upper control arm was assembled at the FF incorrectly. I put the ball joints in the way the manual instructed, but after it was on the chassis I noticed that the grease zerks were pointing down. I labeled a photo of the assembly for others to see how it should go, provided it's right, please let me know for sure.
    Bradley
    Nov 2018
    Centennial, CO
    Lower control arms
    I did add the spacer washer on the driver side, back side of the lower control arm as the manual instructs and one was enough, but on the passenger side I was able to add a spacer to both back and front sides. Washer front.jpeg
    Seems like the right thing to do, though there is a small gap even when torqued down.Gap.jpeg
    Bradley
    You've got it right. The upside down assembly comes from the supplier. Did you use thread locker on the ball joints? If not, you'll want to do so to keep them from backing out. Also, some paint marks will help you monitor if they are moving or not.
    Nov 2018
    Centennial, CO
    Shock and spindles.
    My POL was fairly short and had just small items on it, but unfortunately the spring hat and another shock component are on it. My question to the group would be can I go on to do the spindles and come back to the shocks and springs later? It looks like this shouldn't be a problem, but if it is I can wait.
    Bradley
    Go right ahead.
    Nov 2018
    Centennial, CO
    Thanks Dave I did use the thread locker blue on the ball joints, though the PS ball joint was so tight I can't imagine it ever coming off. I'll put the paint marks on it, good tip.
    Bradley
  8. #88
    Nov 2018
    Centennial, CO
    Cool, I'll go do that right now. You guys are super helpful. Thanks.
    I'd like to post the picture of the body hoisted up to the ceiling, but the darn picture keeps turning upside down when I upload it.
    Bradley
  9. #89
    Nov 2018
    Centennial, CO
    Go right ahead.
    Jeff, I read your post about the bare aluminum panels today. You really have me rethinking the powder coating. I like saving the money and the panels look so good.
    Bradley
  10. #90
    Senior Member VAHokie's Avatar
    Chantilly, VA
    Thanks for the pic and explanation - will be helpful when I start the front suspension. Keep up the good work!
    MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start 11/28/20 l First Go-kart 4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l Build Thread
  11. #91
    Nov 2018
    Centennial, CO
    Sure thing. I’m learning that all sources available are required to avoid problems: FF YouTube videos, the manual and the forum at a minimum. It was telling to see the the guy in the FFR video use an impact wrench on the wheel nuts and the wheel hub box warns against doing just that.
    Bradley
  12. #92
    Nov 2018
    Centennial, CO
    Hubs installed - where’s the grease?
    I know it’s been a long time since I’ve worked on wheel bearings, but is there really no extra grease to put inside before the dust cap goes on?
    Bradley
  13. #93
    No, they are sealed bearings.
    Nov 2018
    Centennial, CO
    I’ve gotten a few things done, although I’m skipping the power steering and shocks for now as both have parts I’m waiting on. In the mean time, I’ve installed the upper and lower control arms on the rear, the center section, axels and the spindles.
    I’m on the rear brakes now and Wilwood instructions say to start with at least one .029” shim, but it appears the caliper is more centered with no shims between the bracket and upright. Does that seem okay? Wilwood only sent me 2 .625 o.d. Washers for the lock nuts that hold the calipers on the brackets. I assume I can get 2 more replacements at the hardware store?
    Bradley
  15. #95
    Do what's necessary to get them centered properly. I've installed those brakes a few times, but don't remember the exact shims required. The instructions are only giving you a starting point. But they give you plenty of extras in difference thicknesses. So add or remove as necessary to get everything aligned properly. I'm surprised about missing hardware. Wilwood is usually really good and thorough about that. I don't recall the exact one you're talking about. But their hardware is all very specific and also hardened. You may be able to find something suitable. Or call Wilwood and I'll bet they'd send what you're missing.
  16. #96
    Nov 2018
    Centennial, CO
    Yeah, It just surprised me that I didn't need any shims. I don't know what happened to this batch, but not only did they short me two washers, they gave me 24 extra washers for the bolts that go on the bolts holding the hat to the disc. I''l give them a call on the missing ones and see if they are special enough to wait on replacements from Wildwood. Thanks for the input.
    Bradley
  17. #97
    Nov 2018
    Centennial, CO
    Installed the IRS center section.
    Cleaned off the writing with acetone and then clear coated the center section.
    Bradley
  18. #98
    Nov 2018
    Centennial, CO
    My son pulled up from the cockpit and I puled up from the trunk. We controlled and supported the center section with ratcheting load straps.
    Bradley
  19. #99
    Looking good!
  20. #100
    Nov 2018
    Centennial, CO
    Axles installed without any drama, heard the click. Rear brakes.
    In this picture you can see that the the center rod has no nut on it (left side). I don't believe it needs one as it has threads in the caliper but the Wilwood instructions say there is a nut there. Maybe a a left-over instruction from previous versions?
    Bradley
  21. #101
    Nov 2018
    Centennial, CO
    The engine arrived today
    Bradley
  22. #102
    Nov 2018
    Centennial, CO
    Looking good!
    Thanks, finally getting some time to get this pictures upload thing figured out.
    Bradley
  23. #103
    Oct 2018
    central Iowa
    Go chiefs!!!!!
  24. Likes GTBradley liked this post
  25. #104
    Don't remember seeing that in the instructions. Must have missed it. But I've used those brakes twice and no nut in that location. Not sure how one would fit anyway unless the bolt were longer.
    Congrats on receiving you Coyote. The fun really starts now.
  26. #105
    Nov 2018
    Centennial, CO
    Thanks. Makes a guy nervous having all this expensive equipment sitting around. Can’t do the e-brake because cable is b/o. I guess I can do break lines this weekend.
    Bradley
  27. #106
    BadAsp427's Avatar
    Greeneville, TN
    You need to return that motor... It appears to be upside down, the oil fill cap should be able to be read correctly. As it is now, you can see the oil will leak out of the oil can... Just sayin'
  28. Likes WIS89, PeteMeindl liked this post
  29. #107
    Nov 2018
    Centennial, CO
    Yeah, but when I turn it right side up the competition is gonna get turned on its ear.
    Bradley
  30. Likes PeteMeindl liked this post
  31. #108
    Nov 2018
    Centennial, CO
    So I haven’t looked into it yet, but why is the engine shipped with one header?
    Bradley
  32. #109
    The other side has a built-in catalytic converter, so they don't include it. I'm assuming because of the value, but I've never heard officially. Doesn't matter, because hopefully you're installing straight tube headers so the stock headers aren't needed.
  33. #110
    Paul,
    The engine's fine, that's the 710 cap …
  34. #111
    Nov 2018
    Centennial, CO
    Thanks, just curious as yes I have the full length 4 to 1 to 4 headers on backorder.
    Bradley
  35. #112
    Nov 2018
    Centennial, CO
    I have the control arms, brakes, center section and axels installed. Snce the backordered parts: spring hats for the shocks; mounting hardware for the power steering and e-brake cable prevent me from finishing those things I’m thinking brake lines would be okay to start. Any suggestions would be welcome.
    Bradley
  36. #113
    Bradley,
    I used Paul's pictures and description of the brake line install in his 20th Anniversary build thread to model mine. His brake line install starts on post #214:
    https://thefactoryfiveforum.com/show...l=1#post229659
  37. Thanks GTBradley thanked for this post
  38. #114
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    Here's a link to how I did mine... fuel for the synapses.
    **Note**
    None of the supplied brake lines were used "out of the box". They were all cut to fit, and new double-flares done when necessary.
    John D. - Minneapolis 'Burbs
  39. #115
    Nov 2018
    Centennial, CO
    **Note**
    nice work on that, now I know what to do. You’re telling me I need a brake line flaring tool too, I think.
    Bradley
  40. #116
    Senior Member cv2065's Avatar
    I used pre-flared lines from Advanced Auto. Worked out great. Just another option for you.
  41. #117
    Minneapolis 'Burbs
    Thanks for the compliment...
    You don't necessarily need a flaring kit - As CV stated you can get lucky piecing it together with pre-made lines - but you may not be able to tuck/tighten the lines up as well due to some extra length.
    I'm using my Dads 50+ year old kit. I have it, so why not. Doing proper double flares isn't difficult once you've practiced a few times on scrap material.
  42. #118
    Nov 2018
    Centennial, CO
    Thanks. I looked into that and ended up buying a bending tool. This is going to get interesting.
    Bradley
  43. #119
    Nov 2018
    Centennial, CO
    I bought a bending tool and expected to use my dad’s 50 year-old flaring tool I’ve been hanging on to since 1987 - broken. Oh well, a new one was not expensive. I spent yesterday making good progress on learning the art of bending/double flaring. I never once forgot to put the fitting on, twice I forgot to slide the fitting past the bends first.
    Im tempted to mount that brake line on the top of the cross bar, opposite yours. I know it wouldn’t be accessible, but how often does one replace a break line? And if I needed to, I have the option of cutting off the excess and leaving the unseen parts up there.
    Bradley
  44. #120
    Bradley,
    If you want, get everything bent up and bring your lines over and we can use my Eastwood flair tool to finish them up.
  45. Likes WIS89 liked this post
