ReinCarNation
Thanks Thanks:  6
Likes Likes:  14
Page 6 of 6 FirstFirst ... 456
Results 201 to 216 of 216
Thread: GTBradley's MKIV build - Full Kit with Coyote, TKO600 and IRS
  1. #201
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    Can I just say, even though it's been said a hundred times already, Damn, that's a wide engine!
    Yup... it's all cylinder head.
    Curious... what are your clearances PS & DS to the footbox tin?
    John D. - Minneapolis 'Burbs
    2018 Mk4 Roadster - #9365 Build Thread
  2. #202
    Nov 2018
    Centennial, CO
    Congratulations. Now the real fun begins.
    Right? So many options. Now I canít decide what I want to work on next. So I just keep working.
    Thanks.
    Roadster Full Kit - IRS - Coyote - TKO600 - 17" Halibrand Replica Wheels - Heater/Defroster - Wipers - Firewall Forward Mod...
    Build thread: https://thefactoryfiveforum.com/show...TKO600-and-IRS
  3. #203
    Nov 2018
    Centennial, CO
    A full inch on the PS foot box. As little as a quarter inch on the drivers side. It’s a half inch on average, but at the bolt bump out it’s a quarter. Is that common?
  4. #204
    Minneapolis 'Burbs
    That's just about exactly what I wound up with.
  5. #205
    Nov 2018
    Centennial, CO
    Can anyone help me with identifying which harness this Intercooler wire is in?
  6. #206
    Ford Coyote control pack harness.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
  7. #207
    Nov 2018
    Centennial, CO
    Does it really need to be cut back, because I can't find it.
  8. #208
    No, it doesn't hurt anything to be there. But a little strange you can't find it. It's item P on the control pack harness, per the Ford instructions.
    https://performanceparts.ford.com/do...-6017-504V.pdf
  9. #209
    Nov 2018
    Centennial, CO
    Ah, thank you. I totally forgot to download that from Ford. I have been using the FFR Coyote Installation instructions exclusively to try and locate it. Everything has been fine until this FFR picture came up. I had identified the right wire on my own, but apparently the FFR picture is old because it shows the wrong colors and that threw me. You've got me back on track once again.
  10. #210
    Nov 2018
    Centennial, CO
    Paul, while you're at it, would you give me your thoughts on this location for my overflow tank? I know you didn't use the FFR tank, but do you think this location will work regarding hood hinges, etc? I can't go more aft as the engine is so wide, so I think I'm stuck with this side of the brake line or a different tank altogether.
  11. #211
    The front to back location will clear the hinges OK. Just watch the height. The gas shock for the hood drops down exactly into that area. Keep it below the bottom of the 3/4-inch hood surround tube (including with the cap) and you'll clear the gas shock.
  12. #212
    Nov 2018
    Centennial, CO
    So the Ford Controls Pack Instruction Sheet says the AC wires come off Takeout CCA, but their picture does not look like what I have. I'm assuming these (pictured below) wires are the same thing. Can anyone with Coyote confirm please?
    These are coming from Takeout CCA, along with the fan wire and starter lead.
  13. #213
    Per the Ford Performance Gen 2 Coyote Control Pack instructions, and my memory, the wires you're picturing here are from the 16-way I/P Pigtail cable. Not the main wiring harness. If those are really in the main harness, then something has changed. i know Ford Performance has made some changes with the later versions of the Control Pack. Later than the Gen 2 version I installed. If that's the case, maybe call the Ford Performance help line. Unless someone else on here has experience with a later version.
  14. #214
    Nov 2018
    Centennial, CO
    You got me to thinkin...I needed the M50A 2017 tech sheet. Those wires I was asking about are intended for Electric Power-Assisted Steering (EPAS) and this one does not have the option for A/C.
  15. #215
    There you go. Hadn't seen that update, but shows some of the changes I've heard about. Nothing that should affect anything with your build. Just different.
  16. #216
    Nov 2018
    Centennial, CO
    In fact, everything had been identical til the A/C wires were missing. Don’t know why they would omit those, but I hadn’t planned on air conditioning here in the mountains anyway.
Replica Promotions
