Thanks Thanks:  3
Likes Likes:  6
Page 3 of 3 FirstFirst 123
Results 81 to 96 of 96
Thread: GTBradley's MKIV build - Full Kit with Coyote, TKO600 and IRS
    Member GTBradley's Avatar
    Nov 2018
    Centennial, CO
    Body and panels are off.
    I built a lightweight/small dolly for the stages before the kit gets heavy and it works pretty well.
    Roadster Full Kit - IRS - Coyote - TKO600 - 17" Halibrand Replica Wheels - Heater/Defroster - Wipers - Firewall Forward Mod...
    Build thread: https://thefactoryfiveforum.com/show...TKO600-and-IRS
    Nov 2018
    Centennial, CO
    Control Arms
    I installed the control arms with some difficulty. I'm pretty sure they are correct now, but the upper control arm was assembled at the FF incorrectly. I put the ball joints in the way the manual instructed, but after it was on the chassis I noticed that the grease zerks were pointing down. I labeled a photo of the assembly for others to see how it should go, provided it's right, please let me know for sure.
    Nov 2018
    Centennial, CO
    Lower control arms
    I did add the spacer washer on the driver side, back side of the lower control arm as the manual instructs and one was enough, but on the passenger side I was able to add a spacer to both back and front sides. Washer front.jpeg
    Seems like the right thing to do, though there is a small gap even when torqued down.Gap.jpeg
    Parker, CO
    You've got it right. The upside down assembly comes from the supplier. Did you use thread locker on the ball joints? If not, you'll want to do so to keep them from backing out. Also, some paint marks will help you monitor if they are moving or not.
    There are 10 types of people in this world;
    those who understand binary and those who don't.
    Nov 2018
    Centennial, CO
    Shock and spindles.
    My POL was fairly short and had just small items on it, but unfortunately the spring hat and another shock component are on it. My question to the group would be can I go on to do the spindles and come back to the shocks and springs later? It looks like this shouldn't be a problem, but if it is I can wait.
    Not a waxer
    Jeff Kleiner's Avatar
    Go right ahead.
    Nov 2018
    Centennial, CO
    Thanks Dave I did use the thread locker blue on the ball joints, though the PS ball joint was so tight I can't imagine it ever coming off. I'll put the paint marks on it, good tip.
  8. #88
    Nov 2018
    Centennial, CO
    Cool, I'll go do that right now. You guys are super helpful. Thanks.
    I'd like to post the picture of the body hoisted up to the ceiling, but the darn picture keeps turning upside down when I upload it.
  9. #89
    Nov 2018
    Centennial, CO
    Go right ahead.
    Jeff, I read your post about the bare aluminum panels today. You really have me rethinking the powder coating. I like saving the money and the panels look so good.
  10. #90
    Member VAHokie's Avatar
    Chantilly, VA
    Thanks for the pic and explanation - will be helpful when I start the front suspension. Keep up the good work!
    MKIV Complete Kit #9494 l Carb'd 306 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Hydraulic Clutch, Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Lower Radiator Support, Fan Shroud l Boig Quiet Pipes l 18" Forgestar F14s
  11. #91
    Nov 2018
    Centennial, CO
    Sure thing. Iím learning that all sources available are required to avoid problems: FF YouTube videos, the manual and the forum at a minimum. It was telling to see the the guy in the FFR video use an impact wrench on the wheel nuts and the wheel hub box warns against doing just that.
  12. #92
    Nov 2018
    Centennial, CO
    Hubs installed - whereís the grease?
    I know itís been a long time since Iíve worked on wheel bearings, but is there really no extra grease to put inside before the dust cap goes on?
  13. #93
    Not a waxer
    I know it’s been a long time since I’ve worked on wheel bearings, but is there really no extra grease to put inside before the dust cap goes on?
    No, they are sealed bearings.
    Nov 2018
    Centennial, CO
    I’ve gotten a few things done, although I’m skipping the power steering and shocks for now as both have parts I’m waiting on. In the mean time, I’ve installed the upper and lower control arms on the rear, the center section, axels and the spindles.
    I’m on the rear brakes now and Wilwood instructions say to start with at least one .029” shim, but it appears the caliper is more centered with no shims between the bracket and upright. Does that seem okay? Wilwood only sent me 2 .625 o.d. Washers for the lock nuts that hold the calipers on the brackets. I assume I can get 2 more replacements at the hardware store?
  15. #95
    edwardb's Avatar
    Do what's necessary to get them centered properly. I've installed those brakes a few times, but don't remember the exact shims required. The instructions are only giving you a starting point. But they give you plenty of extras in difference thicknesses. So add or remove as necessary to get everything aligned properly. I'm surprised about missing hardware. Wilwood is usually really good and thorough about that. I don't recall the exact one you're talking about. But their hardware is all very specific and also hardened. You may be able to find something suitable. Or call Wilwood and I'll bet they'd send what you're missing.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
  16. #96
    Nov 2018
    Centennial, CO
    Yeah, It just surprised me that I didn't need any shims. I don't know what happened to this batch, but not only did they short me two washers, they gave me 24 extra washers for the bolts that go on the bolts holding the hat to the disc. I''l give them a call on the missing ones and see if they are special enough to wait on replacements from Wildwood. Thanks for the input.
