44
161
So what is this existing wire going to the PDB from the coyote wiring harness, does anyone recognize it?
I'm guessing it's at least partially the HAAT (Hot At All Times) power, but does it get connected along with the power wire from the battery through the cutoff switch as shown in the coyote install manual? Or could I connect it to the battery side of the cutoff switch?
Bradley
