44
161
I was concerned about the 10 amp rating on these times two going through my fuse box on a wire that doesn't appear to be a high enough gauge to handle 20 amps, which is also the size of fuse I'm using. I'm using the the electric choke location in the RF (Ron Francis) fuse panel. I turned both seats on high and let run for a while and the wire never heated up so, I guess it's not really pulling that many amps? I'll check it again when the seats are working hard on a cold day
Bradley
