Results 1 to 3 of 3
Thread: Window openings on the top
    Do the window openings on the hard top need to have the lip cut down to 3/4" like the trunk opening? I don't see anything in the Manual about that.
    Aug 2013
    Gatineau, Quebec, canada
    Quote Originally Posted by 60's Kid View Post
    The quick answer is, they dont, however, since they are glue in and not fitted with a rubber slip on/in gasket, I ended up making it even all around such that it looks better even though there is a black barrier all around the window. I did the same on the front as well.
    Prairieville, Louisiana
    They don't necessarily, but I think it looks better. Mainly, I did cut mine down to 3/4" so that it increased available area to see out of. And you would be surprised how much difference that made when I did all 4 of them. Tons more light gets in and area to see out.
    '33 Hot Rod
    MK4 Roadster
  4. Likes AJT '33 liked this post
