Results 1 to 3 of 3
Thread: Gold Flakes
    Oskaloosa Iowa
    Gold Flakes
    Changed out the stock pan for a Moroso on a new unfired gen 2 crate today and found a few gold flakes that I assume is bearing material in the bottom of the pan. Just wondering if any of you guy's have seen that? Maybe it's normal to see some on a new engine but makes me feel a little uneasy. I think I might call Ford Performance tomorrow and see what they say.
    Kirkland, WA
    The engine was delivered with some oil in the pan, right? I understand they turn the engines over (called motoring) in the factory but don't fire them.
    Can you post a picture of the flakes? I don't recall seeing any debris whatsoever in my pan when I swapped out for the Moroso. Definitely would call Ford.
    Oskaloosa Iowa
    Quote Originally Posted by initiator View Post
    Yes, the engine had oil in it when delivered. I called them today and he said it was "Very Common" to see metal in the pan, makes me feel a little better i guess. He said that he has only replaced one engine since they started selling Coyote crates. Not sure how to post pictures but there are probably 2-3 flakes that is 1/16 or so square and a lot of very fine, like glitter that is noticeable in the sun. Time will tell, hopefully have it in and running by spring.
