newer 818 headlight wiring
Good evening,
I am having difficulty on understanding how the new headlight bucket lights are wired.
I have a 2003 WRX wagon
1. Headlights do not operate correctly, low beam good, but highbeams trigger the shutter, but turn off the light (low beam wire looses power). I understand I need to add a relay, but have not been able to wire it correctly, please attach pictures or have a more simple verbaige, such as "low beam wire needs to go to relay post 87"
2. Turn signals flash, I will figure out which is the realy I need to change (another thing missing from the build manual)
