39
91
VAHokie
Thanks, Carl. Dumb question, safe to assume you counter sunk the 7" lag bolts that held the 4x4 and 4x6 pieces together?
Yup.. just used the appropriate size wood bit (Paddle style) Worked great.... That's also why I ended up with the 4x4 on top.... FYI, pre drill with 3/8" bit and use 7/16" Lag bolts... good catch....
