Out of Sight Audio
Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Aluminum Grease Fitting Caps
    Senior Member JOP33's Avatar
    Haslet, Texas
    I am about to place an order for some Aluminum Grease Fitting Caps (apparently these are extremely difficult to find). On the standard 33', I believe there is (18) required. If anyone is interested in piggy-backing on my order please let me know within the next day or two (you can pm me). Current pricing is $5.00 each < 36, $4.00 each 37 to 99 and if we can get to 100...$3.25 each. We will have to calculate shipping, if other's are interested. Below is a pic...
    33' Hot Rod Coupe/Roadster, Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19
    Parker, CO
    You could spend a lot less and get these:
    https://rover.ebay.com/rover/0/0/0?m...2F181682740677
    There are 10 types of people in this world;
    those who understand binary and those who don't.
  3. Thanks Jetfuel, erlihemi thanked for this post
    Haslet, Texas
    Good point and I will check into it...hope the caps fit existing fittings as my time to remove and re-install new fittings would be worth the additional $1.35 a piece .
    Jun 2018
    North Vancouver, BC, Canada
    Quote Originally Posted by JOP33 View Post
    I'm in if you decide to order. Tim W is sold out and they weren't that popular apparently so he isn't going to place another order.
    Senior Member MBB Larry's Avatar
    Feb 2018
    Grapevine, Texas USA
    I'm in Jamie! Whatever you order, get a set for me. Maybe a couple extra??
    Larry
    FFR Hot Rod #1106
    Parker, CO
    I don't think the caps will work without the fittings. Sorry to hijack your thread. I just thought they looked like a decent alternative.
  8. Thanks JOP33 thanked for this post
  9. #7
    Haslet, Texas
    Ok Steve, yes I had checked with Tim as well and got the same answer a couple of months backs. I’ll add you to the list and let you know when I order.
  10. #8
    Haslet, Texas
    Quote Originally Posted by MBB Larry View Post
    Larry
    Got you down Larry.
Lodestone Billetworks
