ReinCarNation
Results 1 to 10 of 10
Thread: Adjustable Seats
    Senior Member MBB Larry's Avatar
    Feb 2018
    Grapevine, Texas USA
    Adjustable Seats
    Being "Vertically Challenged", I am researching Manual Adjustable Seats. Fwd/Aft and Height. I really like the Manual Adjust Seats like the ones in the VW Sports Type. I have seen some VW Ricaro seats that look really nice. Was thinking of a used set, and have them done when I have the Interior completed. Having sat in a completed car, forward visibility is not so good setting so low.
    FFR Hot Rod #1106
    Oct 2014
    Vermilion, OH
    I built an angled seat riser that is 1/4" in the rear and 2-1/2" in the front. You could use the seat adjusters like FFR has and change the amount of height on the riser.
    CVOBill
    Feb 2018
    Thanks. I assume that means when you adjust FWD it also raises the height?
    FFR Hot Rod #1106
    Apr 2014
    Memphis, TN
    I have the Summit sliding seat brackets, sum-g1153. I then took two 1 inch aluminum angle brackets the same length and bolted one to the seat and one to slider, basically the same thing as if I purchased the Sum-G1150 brackets. That allows me a bit of adjustability in placing the seats in the car, and then the sliding front and back as I need it. That also gets the seat off the floor around 3 inches. How vertically challenged are you? I am 5'7" and all in all this seems pretty comfortable to me when I have go-carted around my neighborhood.
    Ryan
    33 Hot Rod
    Oct 2014
    Vermilion, OH
    Quote Originally Posted by MBB Larry View Post
    Larry, I installed my seats all of the way back. But you're correct, unless you put the adjusters on the bottom.
    CVOBill
    Feb 2018
    I am a tall 5'6". OK for the Army, but don't want to have a "NO FENDER BENDER" on a curb or bump. I also looked at a Kenwood Dual Camera Screen today.
    FFR Hot Rod #1106
    Placitas, NM
    I used some sliders from a Jeep website, then added more metal to raise the bottom of the seat frame up 3.5" from the floor. Visibility to the right front corner is non-existent.
    I'm also looking into a dual camera stereo setup.
    '33 Hotrod, #1047, delivered on 2/27/18, go cart on 9/24/18.
    LS3 w/4L65e, Lokar shifter, Electric PS, Vintage AC/Heat/Def, 8.8" 3.55
    TorqThrust II Wheels w/Toyo Proxy T1 Sport Tires, F 245/45ZR17 R 295/35ZR18
    Feb 2018
    Thanks, I will check it out. You install on both sides??
    FFR Hot Rod #1106
    Placitas, NM
    Yes, on both sides.
    Here are the ones I bought.
    https://www.4wd.com/p/mastercraft-sa.../R-GNNN-620030
    Nov 2018
    Chandler, AZ
    Great info. Thanks!!
