This was installed and run on my FFR Mk4 roadster for about 350 miles. Works just fine. Was swapped for the Pro-M pump hanger on the advice of my tuner. Replaced the pump at the same time, so this one is up for sale.
Originally purchased from Breeze as part number 70734, 190 LPH In-Tank EFI Fuel Pump with 3/8" Outlet: https://www.breezeautomotive.com/sho...th-3-8-outlet/. According to the Breeze website, will support 470 flywheel hp with a 10% safety factor. Also includes the Breeze 70736 06AN supply and return adapter fittings which are needed to attach 06AN style hoses to the pump hanger. These are priced at $199 and $28, respectively if purchased new. Asking $50 plus $10 for shipping.
You'll need a new sock filter (Walbro 125-157 or equivalent), and 06AN hoses to connect to the fittings on the hanger. Since the Breeze 70736 are swage fittings, I don't believe they can be removed without cutting them off. The use of 06AN supply and return hoses will allow direct connection to the existing fittings without any modifications.
Photos below. Thanks for looking.
