Results 1 to 5 of 5
Thread: 5/16 Fuel lines with LS Motor
Hybrid View
    Nov 2018
    The 5/16" fuel lines supplied with the kit seem too small to handle an LS Motor. The GM OE lines are all 3/8". I'm thinking of upsizing but some of the fitting supplied with the EFI Kit choke the flow down to barely 1/4". Any suggestions?
    I'm NOT running an E.F.I. set up; however, I was able to get a 3/8" pick up via my local NAPA auto parts store since a friend of mine manages it. We ordered all the different Mustang pick up part numbers to see what would show up and found that we had a Winner, Winner Chicken Dinner moment. I ran the 3/8" feed line, since I'm running a mechanical pump, but didn't need to run a return line since my system is Stupid Simple compared to yours.
    My suggestion would be to contact Mark Reynolds at Breeze Automotive because I'm sure he'll have a solution for you, especially if your pump is externally mounted.
    His link below may be of some help to you:
    https://www.breezeautomotive.com/?s=...t_type=product
    Good Luck Fellow Dark Sider!
    Chino Valley, Arizona
    I had that same concern for my EFI (multiport) 347 and called FFR. They said they are running 5/16 lines on their EFI 500 horse 363 SBF. They indicated 500 horse is the upper threshold for 5/16 lines. The smaller lines for EFI run a much higher pressure compared to the lower pressure larger volume mechanical lines.
    Do not know what your LS motor is putting out for power, but my 450 horse 347 with 5/16 lines runs just fine.
  4. Thanks GBPCAZ thanked for this post
    Nov 2018
    Thanks for the info. I'm not planning on over 400HP. Aging out of insane power to weight ratios!
    Village Mills, Texas
    I have the 376/480 which is 495 hp. I bought 3/8 steel lines for the supply and used the 5/16 lines for the purge canister.
