Thanks Thanks:  4
Results 1 to 12 of 12
Thread: Bonneville Salt Flats Question
    Sherwood Park, Alberta
    I am planning on attending Huntington Beach again this year from Alberta Canada. I am wondering if anybody has local knowledge of the area. Is the end of April too early to get on the lake bed? Is there a wet season, snow melt etc...
    Not really looking to do any high speed runs but more of a bucket list thing to do. Photo op time as well.
    Troy
    " The journey is the reward" Chinese Proverb
    FFR Roadster #5380
    FFR Spyder GT #030
    Placitas, NM
    Are you saying you want to run your car at Bonneville?
    If so have you looked at the requirements to pass tech?
    '33 Hotrod, #1047, delivered on 2/27/18, go cart on 9/24/18.
    LS3 w/4L65e, Lokar shifter, Electric PS, Vintage AC/Heat/Def, 8.8" 3.55
    TorqThrust II Wheels w/Toyo Proxy T1 Sport Tires, F 245/45ZR17 R 295/35ZR18
    No I don't want to race my cars in an event. I would just like to drive on the lake bed and also do some photo shots. I'm going to be driving past the salt flats this year on my annual trip to Huntington Beach.
    Troy
    FFR Roadster #5380
    FFR Spyder GT #030
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Word of caution, I was looking at running my '65 Mustang vintage racer there and all of the stuff I read from past competitors said that the salt will get everywhere in the car - especially all the seams, nooks, and crannies on the underside. Once there, it will attract and hold moisture and contribute to some nasty corrosion - and you'll likely never get it all out unless you strip the car down to the bare elements and clean everything.
    Based on that, I took Bonneville off my bucket list and replaced it with the Pikes Peak hill climb. Now to just avoid falling off that big mountain.
    Later,
    Mk3.1 #7074
  5. Thanks 7tvette thanked for this post
    Member Arvin's Avatar
    Layton, Utah
    I live just north of Salk Lake. April could be a bit sketchy for water. You may find a place for a photo but I wouldn't count on a long run down the salt flats.
    FFR Complete MKIV Kit (#8271)
    Ordered: Jan 21, 14, Registered: Aug 19, 15
    408 Keith Craft Engine (512 hp, 534 ftlb), Tremec TKO600, Fast EFI, 8.8 Solid 3.55:1 Rear End, FFR Replica Halibrands (9 & 10-1/2"),
    Dual Chrome Roll Bars/Bumpers/Polished Exhaust, Guardsman Blue with Wimbledon White Stripes
  7. Thanks 7tvette thanked for this post
  8. #6
    Layton, Utah
    https://rove.me/to/utah/flooded-bonneville-salt-flats
    "Approximately 15,000 years ago, there was an enormous lake that covered around two-thirds of Utah. Nowadays, it has completely dried up and turned into a vast salt carpet. Currently, its surface covers the area of 1,214 square km. It looks like a frozen lake covered with snow but only until the wet season. In winter and spring, namely November through May, the water collects on the surface of flats and creates a magical mirror effect."
  9. #7
    Quote Originally Posted by Gumball View Post
    You could take the Mustang to El Mirage, dry lake racing is on dirt not salt so similar experience with less damage to the car.
    It's less formal and a bit slower speeds from the shorter track and traction issues so tech isn't quite as extensive either.
    Dale
  10. #8
    Ol Skool
    upstate NY
    Antelope Island north of Salt Lake City might not be bad for a photo shoot. Just keep the car away from the Bison!! The bugs aren't as bad in the early spring and the water may be a little higher.
  11. Thanks 7tvette thanked for this post
  12. #9
    Senior Member TDSapp's Avatar
    Frisco, TX
    Depending on your driving route you might also consider the Black Rock desert in Northern Nevada. The desert is home of a few land speed records and some rocketry records as well. There is no salt but I will tell you that the sand is like talcum powder and will get everywhere. I went there 10 years ago for a rocket launch and still have some items with the sand in it.
    Driving on it is great though... You can do 90 mph out there and feel like you are sitting still because there is nothing around you to let you perceive your speed.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  13. Thanks 7tvette thanked for this post
  14. #10
    OK, I just Googled Black Rock Desert. I'm freaked out....what the hell is that semi-circular community in the South central part of the lake bed? Looks like a scene from a Mad Max movie!!
    Troy
    FFR Roadster #5380
    FFR Spyder GT #030
  15. #11
    Frisco, TX
    Quote Originally Posted by 7tvette View Post
    Troy
    Well the Black Rock Desert is home to a few annual events. For my other hobby of High Power Rocketry it is home to an annual Rocket launch called Balls. It attracts a few hundred guys with the biggest and baddest rockets to the site for a clear recovery area and high altitude waivers.
    In another part of the year Black Rock is home of Burning Man. Here is a clip of the description of Burning Man.
    "Dedicated to anti-consumerism and self-expression, the Burning Man art festival, which attracted more than 35,000 participants in 2005, traditionally culminates with the burning of a large wooden sculpture of a man. ... Today, Burning Man is celebrated on an empty lake bed in Nevada's Black Rock Desert."
    Basically it's Hippie Fest in the middle of the desert.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  16. #12
    On a roll
    Al_C's Avatar
    Wheaton, IL
    I've been talking about visiting Burning Man for several years. Haven't gotten much interest from my wife, though. I don't know if I could even interest the dog. Based on what I've read about it, and some of the "sculptures" I've seen, it's probably crazier than I could imagine. But, just picture a whole bunch of Factory Fives at the festival. It's held over Labor Day annually. Food for thought.
    Mk IV Roadster - #8650 - delivered 7-17-2015 - first start 7-28-2018 - first go-kart 10-13-2018: a work in (slow) progress
Flat Irons Tuning
