0
0
Missing clutch sensor plug, 15-17 Coyote Harness
Finished up both the sensor locations for the clutch sensors for the coyote harness, plugged in the bottom (safety) sensor and then had a WTF moment when I reach for the other plug..... I Went back and read the Ford intructions to make sure I was not crazy and sure enough The last connections on the harness, HH I believe, shows four different connections; ground, apps, clutch bottom, clutch top. I do not have a clutch top.... Anybody ever run into this problem? Any Ideas. Coyote 2015-17 harness purchased new. Every other connection, sans the apps, is hooked up and looks good. Any Help, thoughts, or even some comfort, is appreiciated. Thanks.
