Thanks Thanks:  3
Likes Likes:  22
Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 166
Thread: please critique my (already started) bodywork stages
    Just do the bottoms first. Seal, paint, clear. Let them dry for two days. Prep the tops, mask the bottoms and start painting shooting the rest of the car. Sealer (wait 1 hour) , stripe color down the center (wait one hour), set hood and decklid in place and lay out stripes. Remove hood and decklid and finish taping edges and fully masking off stripes. NOW CALL IT A DAY ! 2nd day. You are going to need to do a little light sanding on the over spray (we should have another phone chat for that). Shoot body color, unmask stripes, shoot clearcoat.....
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Thanks.
    That'll be much easier I think.
    Last time we chatted, you had said I'll need to "scuff" off the over-spray with a gray scotch brite pad.
    That still the case? Or.. does the master have still more to teach this Padawan learner?
    Gray SB is good but where the overspray is heavy you want to hit it with some 600 dry.....maybe using the SB as a backing pad...…...NEVERMIND! I'LL JUST COME OVER THERE AND DO IT MYSELF...…...da bat
    Jan 2016
    SA-TX
    I'll have the Rum waiting for you!!
    Jan 2016
    SA-TX
    The Spray Booth is about 1/2 done. It's up, the seams are all sealed with duct tape, and a bunch of led strips for added lighting. The leds, along with the main shop lights.. and ... the ambient light from the open garage doors (I'll be spraying during the day) provide plenty of light to see what I'm doing. There's more light than it looks in the photos due to the auto white balance of my phone camera. Still need to seal in my blower fan and the hvac filters. That'll be tomorrows project. Tonight.. Beer-o-clock.
    Jan 2016
    SA-TX
    Paint Purchased!!
    Going to spray the underside of the hood, scoop and trunk this weekend.
    Then.. next weekend... the rest.
    The light at the end of the tunnel is in sight! I just hope it's not an oncoming train
  7. Likes JETAV8R, FF33rod liked this post
  8. #87
    Cant wait to see color!!
  9. #88
    Jan 2016
    SA-TX
    You and me both!!
  10. Likes Boydster liked this post
  11. #89
    Jus cuz I taint sed nuttin don't meen I aint got my I on you boy ….Good shootin brother.
  12. #90
    Jan 2016
    SA-TX
  13. #91
    Well...
    Jan 2016
    SA-TX
    Just ordered this from Amazon.
    It says will render the wearer totally invisible to all people named Jeff.
    I should be safe now.
  15. #93
    Catonsville, Maryland
    Quote Originally Posted by skidd View Post
    OHHHHH Your in for it now. Obviously you haven't learn this lesson:
    You don't tug on batman's cape
    You don't spit into the wind
    You don't pull the mask off that old lone ranger
    And you don't mess around with the Jeff
    Nice knowing ya.
    Ron
  16. #94
    Oh! I love those things. Been sleeping in mine for years now. The sad part about them is that as cool as they make you look when you are out and about...they are useless. They really only work when the sun goes out ….. That's when the fart harvesting butt probers start broadcasting to the more intellectual cross section of the planet. WHAT ! This is serious.....I wouldn't make this stuff up.....again....da bat
  17. #95
    Jan 2016
    SA-TX
    Ok... I need some EMERGENCY help.
    I just put coat #1 on the bottom of the hood trunk and scoop.
    FISHEYE!!
    I need to know what to do at this point.
    I sprayed the hood first, got a few, the trunk 2nd got a FREAKIN' CRAP LOAD, scooop; 3rd and got just a couple.
    I have a desicant water trap in my air line, before the filter and regulator. And a very large black-pipe based water trap right after the tank,
    And, one of those cheap disposable filters at the gun.
    I pre-paint wiped down all surfaces, then tack-clothed them all.
    Is this crap I left behind on the panel? Or .. something in my air line?
    Here is the worst spot on the trunk
    What do I do? I'm going to need to stop, let it dry, and sand it, right?
    Of all the things that could go wrong.. this is the worst case scenario.
  18. #96
    Jan 2016
    SA-TX
    Well.. I'm committed now. (count down to daBat beat down starts now)
    I called a buddy of mine who has far more experience than I have.
    Showed him the pic, asked for guidance.
    He said. "stop... let it cure, sand it and start over again".
    I was not happy with this advice. but.. I made my bed.. time to sleep in it.
    I asked him.. nothing else I can do huh?
    he said.. "well.. uh.. yeah. .no. I mean.. uh.. well.. No".
    ?? I heard that.. what are you not telling me.
    He said.. I have tried something with marginal success . If you try it, it's all on you.
    he said, try a few light "dusting" coats over the fish eye. See if it starts to cover it.
    If it does, go ahead and try a normal coat after that.
    It will NOT fill the craters, but it "might" emphases on "MIGHT" cover the fisheyes.
    So.. I figured.. .if I'm going to have to sand it worst case.. I'll try this first.
    It pretty much worked. Actually better than he lead me to believe it might.
    The fisheys did leave small craters, but at least it's the under-panel surfaces.
    I actually have to look close to see them, but they are there.
    Good news: at least I don't think I can blame my air supply.
    Bad news: clearly I didn't do a good enough job cleaning the surface.
    Good news: It's the under panels that this happened on, and I can live with that.
    Bad news: daBat and Kleiner are going to see this soon.. and I'm gonna git'it!!
  19. #97
    I'd have taken it off rather than trying to bury it... I'm going to leave this one to Dr. Miller because he's the chemist (in spite of the fact that I like blowing smoke up his skirt he's one smart guy and you can take his advise on problems like this to the bank). Lots of things could have caused it so the big concern is what. Compressor blowing oil? Contamination in your hose (my paint hoses only get plugged into air that's been through the dryer/separator, never the regular shop air)? I don't think it's residue left from a final wash cleaner---in my experience that will craze rather than fisheye. It will be interesting to see what daBat has to say.
    Sorry man
    Jan 2016
    SA-TX
    Got ahold of daBat on the phone.. and he talked me down from the ledge!!
    Good news is, he's fine with the "cover it up" I did.
    Especially given they are under panel locations.
    We went through how to avoid it happening next weekend when I do the rest of the car.
    In short... I need to "wash" the whole car again.
    We both more-or-less agree it was something on the panel, because I'm getting no more fisheye after that initial one.
    So, it's almost certainly not in my lines. (fingers crossed).
    Plus... I didn't put down sealer on these underside panels, while I intend to put down sealer on the main surfaces next weekend. Technically, that gives me a layer of "oops" to recover from.
    Here is the result of my "dusting" repair, and 2 coats of clear (2 more to go). I'm really quite content with it .. again.. given it's under the trunk afterall.
  21. #99
    Member JETAV8R's Avatar
    Apr 2018
    Wilson, NC
    Great recovery!
    MKIV Roadster #9414, Complete Kit Delivered 9/8/2018, First Start 11/9/2018, First Go Cart 11/10/2018, Ford 306 Hand Built, E303 Cam, Blueprint Engine Heads, Edelbrock Performer Manifold, Edelbrock AVS2 Carb, Roller Rockers, Tremec T5, 3.55 Moser 3 Link, 17" Halibrand Replicas, Nitto 555 G2's, Power Steering, Power Brakes, Heated Seats, Russ Thompson Turn Signal
  22. #100
    4 coats of clear on the bottoms?.....SAVE SOME CLEAR FOR THE REST OF THE JOB !...… WHAT CLEAR ARE WE USING AGAIN ? I WORRY WITH DOING 4 COATS YOU COULD HAVE SOME SOLVENT "MICRO POP" PROBLEMS. 3 max.... sorry for yelling....my radio was turned up and didn't know if you could hear me...da Bat
  23. #101
    sorry man
    Well, I do like having smoke blown up my skirt....and he likes doing it (his words)…..One more time O-Ring and we'll be married in 16 states ! xoxo...da Bat
  24. #102
    Jan 2016
    SA-TX
    Quote Originally Posted by j.miller View Post
    The clear I went with was the PPG Vibrance Line. per yer recommendations. See.. I do sometimes listen!!.. sometimes.
    I mixed up 16oz of the stuff, and figured I might as well use it since I can't save it. Hope I don't get these micro-pops ya speak of.
    coat 1 was pretty light. I might have been a bit paranoid from the base color fish-eye, so I went a bit light to start. coats 2,3 and 4 were pretty wet.
    It's all been baking in my garage with the heater set on max (30c/85F) for about the last hour.
    Looks pretty good so far. A ittle bit of orange peel in a couple of places, a couple of dust specs.. but most of it seems to have leveled out pretty nicely.
    Actually.. the problem spots on the trunk surface.. where all that fisheye was.. looks almost the best! Whodathunkit. I looked as close as I could, and couldn't find the fisheye craters.
  25. #103
    OK, so with the Vibrance gives you alotta film build. To put 4 coats on you need skill and patience (I do not recommend you try). 3 coats with 12-15 mins between at 75* to where the clear is sticky but no longer stringy (checked on the body in the gas cap recess, under tail light gasket covered area and same in front under marker lamp. checked on doors under door latch area. checked on decklid under plate light) Loading wet on wet will get you into trouble with the micro pop (that is solvents trapped in the first coat trying to escape through a drying top coat)
  26. #104
    Jan 2016
    SA-TX
    Would I see these micro-pops by now? Because as of this morning, the under panels look really good! A few dust particles which have introduce tiny "bumps" in the finish, and a couple of minor orangepeel spots. and what looks perhaps like a spot of tiger-stripe right beside the scoop opening (see pic). But, no bubbles under the surface anywhere. Did I escape this round relatively unscathed all things considered? Truth be told, except for the handfull of dust bits, these panels turned out fantastic. Despite the trunk looking like the face of the moon after coat #1. I looked as close as i could, and I can not find any of the fisheye craters or anything.
    Hey.. when It eventually comes time to color sand the whole car... do these underside panel surfaces get wet sanded and polished too? Or .. to they generally get left alone?
    P.S. I'm absolutely in LOVE with this color!! There is no doubt in my mind I made the right choice.
  27. #105
    OH SHUT UP !! Yes you would see them by now. Best I can describe is kinda looks like sugar on the surface. God bless beginners luck.....but now that you have used it all up on the bottoms (WHO DOES THAT ) be mindful of all we have talked about. I do nib and polish the bottom of the hood but not the deck lid (cause it's not my car and I don't care). It's really up to you......god knows ya got enough material ta work with under there ! Stay in touch brother. I will try to be available to you on paint day ….answer questions, hold your hand, talk you down from the ledge,,,,,,OH LOOK ! HE'S LAYING IN THE DRIVEWAY MAKING "GRAVEL ANGELS".....FACE DOWN ! ….I wonder what went wrong. Yeah, it's like that !
  28. #106
    Jan 2016
    SA-TX
    Beginners Luck FTMFW!!
    A wise old sage once told me... "Beginners Luck is the reason seasoned professionals give for newbs proving that any joker can actually do their job".
    Seriously though.. thanks for the help Miller. I was freakin' nervous as hell right before pulling the trigger on the first coat. I've dropped a pretty large chunk of $$$ on this paint, and screwing it up was going to hurt. I think I stood there with the gun aimed for about 2 minutes before I grew the coconuts to pull the trigger. Then to see that fisheye fiasco.. I thought I was toast!! Pulled that one out of my a$$.
    Now...
    I have my next weekend planned now. Weather permitting.
    Friday: clean, scuff, dry (beer); Mask painted surfaces; (beer)
    Saturday: Spray Sealer (beer); Spray Black primary stripes (beer); Mask Primary Stripes (beer); Spray Silver pin-stripes (beer);
    Sunday: Mask silver pin stripes (beer); Spray Primary Color (beer); Spray Clear (beer)
    Monday: Go see doctor to remove rocks from face after making gravel angels. Stop to buy more beer on the way home.
  29. #107
    Are you separating the third color pinstripe from the main stripe or are you having it against the stripe like this:
    If you're going to do it like the photo I use a different sequence---spray the pinstripe color, mask it, spray stripe color, mask it, spray primary, unmask, spray clear. Everywhere you see a comma in that sentence add beer. Don't forget to also add it after clear. Now, I know my friend Miller does it differently...instead of adding beer at every comma he adds rum.
    O
  30. #108
    Now...
    Geeze! Did you and Miller buy the same defective respirators? I grew up in my Dad's body shop, I know the symptoms. All kidding aside, you're doing a great job!
  31. #109
    Lets talk on thurs or Friday about stripe layout.....I got secrets I'll share...da Bat
  32. #110
    Jan 2016
    SA-TX
    Respirator? is that a thing? kidding. Not sure if we got the same defective respirators, but I'm pretty sure we've been drinking from the same defective rum. PPG-DT885 right? same rum you drink right Miller?
    Thanks for the props though. I'm havin' a blast learning this as I go.
    @Kleiner.
    This is what my inspiration is. Slightly different colors, but this layout. So.. silver pin-stripes around the main black stripe.
    In my head, as I imagine laying out the masking, it always seems easier to do the black, then the silver.
    But, I also know full well that putting black on top of silver is far easier than the other way around.
    silver -> black -> main color?
    or
    black -> siver -> main color?
    The thing I like about putting down the silver first, is it seems easier to mask that stripe, and slap down the black on top of it.
    Then, just add to the mask after laying down the black. Though, I sure as hell have to get the placement of the masking tape perfect.
    Where as,building out the mask from the black, out to the silver seems less prone to error.
    Dang you freakin' painters. Dang crazy bunch. the whole lot of you!!
  33. #111
    Oh god no ! I never drink reducer...…..I'm 60. I have to drink "Hardener"...…..unless it last for 4 hours...…..THEN YA DRINK THE REDUCER !......there's a saying. Hardener before reducer you'll never get looser. Reducer before hardener , you're gonna owe her an apology. So, I know it doesn't rhyme but I didn't just make it up......I didn't.....NO I DIDN'T...……….I'M TELLIN MY MOM !!!!
  34. #112
    Jan 2016
    SA-TX
    Anybody have preference/opinion on stripe taping sequences? Both of these seem perfectly viable, and one seems a touch easier and less error prone.
    This is the template I'm planning to use
    https://drive.google.com/file/d/0B3_...RSalZ3QXVtOVE/
    Masking materials I currently have on hand:
    • 1x roll of 3m vinyl tape 1" x 36yrd
    • 1x roll of 3m vinyl tape 1/4" x 36yrd
    • 1x roll of 3m vinyl tape 1/8" x 36yrd
    • 2x rolls of 3m 36mm green automotive masking tape
    • 2x rolls of 3m 48mm green automotive masking tape
    • lots of that 3m blue tape from Home Depot.
    • roll of general purpose brown masking paper.
    Option 1: (main stripe -> pin stripe -> base color)
    1. Spray black primary stripe color. Cary to approx to body gullys.
    2. Pull 36mm (1.4") 3m green tape line down center of entire car as guide.
    3. Pull 1" blue vinyl tape beside center guide tape.
    4. Remove 36mm center guide tape.
    5. Measure out to other side of both stripes.
    6. Pull 1" vinyl tape at outter edge measurements.
    7. Fill primary stripe mask area with 48mm green 3m tape
    8. Spray silver pin stripe down center and both edges of masked black stripes
    9. Pull 1/4" vinyl tape at exact edge of black masked areas.
    10. Spray base color (gray) on whole shee-bang
    Option 2: (pin stripe -> main stripe -> base color)
    1. Measure out and Spray silver down center and outside edges.
    2. pull 1" vinyl tape down center as guide
    3. pull 1/4" vinyl tape tight along center guide
    4. Remove 1" center tape.
    5. Measure out and pull 1/4" vinyl tape for outer pin stripes
    6. Spray black primary stripe color
    7. On top of pin-stripe tape, tape and fill black main stripe. (silver and black are all covered.
    8. Spray Base Color.
    Option 2 somehow seems less error prone to me. If I spend the time and effort to perfectly lay out the 4 pin stripes. and I mean PERFECTLY!! Then masking the black is easier because I just have to run tape on top of the pin-stripe masks. No need to try and get a run of tape perfectly beside another run of tape.
  35. #113
    o
  36. #114
    Jan 2016
    SA-TX
    Thanks Kleiner.
    If I do go option #2, (which I'm leaning to)... is it worth running a bunch of brown masking paper on the outer edge before spraying the black primary stripe? In an effort to keep from trying to cover "black" with "gray"? And .. to keep any over-spray down too?
    Or .. just spray the black to the body gullies and let teh gray do it's thing on top of the black? Just a bit paranoid about trying to cover that black paint with the gray paint.
  37. #115
    C'mon, man, spray the thing already! Ok, just kidding, had to get that out, Whew. Thanks.
  38. #116
    Oh hell go with #2. I wouldn't use vinyl tape to pull the center (too stretchy) I use 1" blue painters tape for that. Doesn't stretch and it's lower tack...da bat......I wouldn't go with # 2 either but I want to see if you still have the "luck"
  39. #117
    Jan 2016
    SA-TX
    Your wish is my command!!
    I'm ahead of schedule today, and the weather is good. 55F outside, but a nice 70F in my garage with the heater running.
    So.. Planning now to get the sealer sprayed on in the next hour or so. Let it dry enough... then the 1st stripe color.
    Then, tomorrow morning 1st thing, I'll spend the time necessary to lay out the stripe masking.
    Which, if things go smooth, should have all layers done by the end of the day. Left to bake in my garage all night at 85F
    Since a cold-snap is in the forecast for Sunday, this should work out well.
    So.. it BEGINS!!
  40. Likes Boydster liked this post
  41. #118
    Jan 2016
    SA-TX
    So far... So good!
    Sealer went on nice. No orange peel, can't see any overspray (not that I have an expert eye) , and most importantly... NO FISHEYE!!!
    Now, beer break while I let the sealer dry enough for the pin stripe color.
  42. Likes JETAV8R liked this post
  43. #119
    Apr 2018
    Wilson, NC
    Good luck today. Waiting for pictures!
  44. #120
    Jan 2016
    SA-TX
    Beer Break!!
    Stripe masking went pretty well. Took a bit over 3 hours to lay them out.
    Both primary and pin-stripe colors went on pretty well.
    Now, I'm waiting until the stripe color is dry for final masking.
    Then.. main color!!
